civic 2000 exr hard start when hot
Every day by mornings it starts withtout a problem, but once the car is hot, and y got an stop at least for 5 minutes, the car just dont want to start, i have cleaning the iac valve, fuel filter, air filter, also soldering the main relay, and the problem persist, i´ve seen many post of people with this problem but, nobody clarifies if it was solved or not, i hope you can help me, i've burned my brain
Re: civic 2000 exr hard start when hot
Every car made from 1996 and up have a crank sensor. That mean that as soon the crank sensor get ho its not sending the signal to start so you have to wait to do it. Make sure you buy it. Please before doing this job disconnect the ground.
Ahhhh.....
Those are called EX (96-98), & SI (99-00) up here.
(Both SOHC)
Your Si/EM1/DOHC is called SIR up here.
EXR's are the top model for Accords 90-97 up here.
My bad.
So your car stalls once warm, & won't start or drive until it cools down?
Unrelated, but it deals with 1 of the parts listed:
I had rough cold starts, & this helped me.
If cleaning those parts don't help, try replacing the IVAC.
(Both SOHC)
My bad.
i put my fans direct and it helps a little, it starts quicker
Ahhhh.....
(Both SOHC)
My bad.
(Both SOHC)
My bad.
yeah if its warn it wont start, i need to wait a couple of minutes, any ideas, i have change gas pump, main relay is ok, temp sensor ok, timing its a little forward
Please did you check the crank sensor.
he means the one on the oil pump, under the black plastic behind the main crank pulley. would be CKF sensor you want to check out. CKP is on the distributor shaft.
Sensor Ckp (de Posicion De Cigüeñal) Honda Civic 96-00; Sp0 - $ 510.00 en MercadoLibre
its kinda confusing because it says ckp but the real thing is that its a ckf sensor.
i have read on some post that this problem might be because a failure cooling sensor, today i disconect this sensor and i start the engine without a problem, then put it back againt, and the failure was there, tomorrow i'll buy a new sensor and check if it solves my problem, i hope it will, pls cross fingers!!
well guys, i finally solve my problem, it was the ect sensor, the way i realise that problem, was unplugging the conector and the car was starting with no problem, once i plug in againt it fails,
thanks for your help
needlesmcgirk
04-06-2010 08:18 PM
kikacha
06-29-2007 02:52 PM
