Fuel pump won't prime
Old Sep 23, 2014 | 04:28 AM
Dustin19902's Avatar
Default Fuel pump won't prime
the fuel pump won't prime sometimes I hear the main relay click when it's in the on position but no fuel pump then sometimes it will prime and no problems runs great need help thank you
Old Sep 23, 2014 | 04:29 AM
Default Re: Fuel pump won't prime
Sorry it's a 93 civic ex no mods thanks
Old Sep 23, 2014 | 09:10 AM
EsotericImage's Avatar
Retired Moderator
Sounds like a crack in the relay solder. change the fuel pump relay and try again
Old Sep 23, 2014 | 10:55 AM
I resodered the relay I think it maybe the ecu bc once it starts it runs great
Old Sep 23, 2014 | 10:57 AM
Default 93 Honda Civic fuel pump delay to prime
the fuel pump has a delay to prime sometimes. I hear the main relay click when it's in the on position but no fuel pump then sometimes it will prime and no problems runs great need help thank you
Old Sep 23, 2014 | 12:46 PM
OJdm's Avatar
i just had this same problem. main relay went bad (cracked solder) replaced. still wouldn't start, so i opened the ecu and that was bad as well. so i had to replace both the main relay and ecu, now starts every time
Old Sep 23, 2014 | 01:02 PM
Where did u get a new ecu from? And did it work fine when it was warm?
Old Sep 23, 2014 | 02:07 PM
OJdm's Avatar
knew a local guy that tunes ecus in my area and he sold me one. works fine warm or cold
Old Sep 23, 2014 | 02:09 PM
You in fl by chance lol
Old Sep 24, 2014 | 06:10 PM
OJdm's Avatar
yes i am, central fl to be exact.
Old Sep 25, 2014 | 03:39 PM
delsolintegra's Avatar
phearable.net
Old Nov 18, 2014 | 12:34 PM
New ecu fixed the problem thanks
slowEGles
May 13, 2013 06:16 PM
bsyeth
Jul 6, 2012 10:56 PM
3easy21
Jun 11, 2012 07:27 PM
Got_EF8
Sep 24, 2008 10:38 PM
iwhichisme
Sep 8, 2004 04:13 AM
