problem with ek automatic
Old Sep 21, 2014 | 11:33 PM
jose5673's Avatar
Default problem with ek automatic
While drving on highway I get a check engine light code believe p0720 something about converter. Now I changed pretty much all sensor externally and also change fluid hoping for the problem to go away. No slips no problems with tranny it shifts perfect but it has that code and will not pass inspection in my state. Help from some one will be highly appreciated.. thanks
Old Sep 22, 2014 | 02:17 AM
MisereNoire's Avatar
Default Re: problem with ek automatic
P0720 is generally referring to the VSS...so either a fault in the speed sensor itself, or in the wiring/circuit...check your wiring for cracks, bare wire, kinks indicating a broken wire in sheath...also you might try a continuity check on those wires...if your wires/harness check out fine, look into the sensor itself. BUUUT yeah...auto ek=eventual fail. bad auto trannys and all.
Old Sep 22, 2014 | 08:02 AM
jose5673's Avatar
Do you know what kind of voltage should i be getting from each wire??
ArtyTheKid
Aug 16, 2013 11:52 AM
mtime
Dec 17, 2009 09:17 PM
BlueRex1020
11
Mar 23, 2007 08:06 PM
salman
10
Jul 6, 2006 05:41 PM
iluznxpnoi
Jan 10, 2002 10:17 PM
