ls swap cooling system
Old Sep 21, 2014 | 06:08 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default ls swap cooling system
I have a b18b1 I am chasing down a cooling issue with. The guy I bought it from was not very bright, and sold it to me thinking it had a head or gasket issues. I drove it home, no overheating at all. Coolant and oil are not mixed. Compression test was 210-190-200-180. Passed block test with flying colors. Here is what it is doing- the system seems to be overpressurizing. The upper and lower hoses are rock hard to the touch with the engine running, and it has burst two smaller coolant hoses running at idle. It does not force coolant into the res, it does not overheat. Ideas?
Old Sep 21, 2014 | 06:31 PM
Norlael's Avatar
Default Re: ls swap cooling system
replace radiator cap
Old Sep 21, 2014 | 08:06 PM
Already did, with a known good one from my daily.
Old Sep 21, 2014 | 08:26 PM
Could this be a water pump? The cap should relieve the excess pressure, but without circulation it couldn't do its job. I'm stumped.
Old Sep 21, 2014 | 08:29 PM
tony_2018's Avatar
Fish Twig
He might have use a gasket sealer in the system so chances are maybe passage ways could be blocked.
edit: try leaving the cap off while the car warms up and idles to see if any bubbles produce. If nothing than replace the cap with a good one.
edit 2: I mistaken the replacement part as the thermostat part being replace, since the cap was replace then the next thing to look at is the thermostat, it might not be opening up.
Old Sep 21, 2014 | 09:39 PM
The first thing I did was bleed it. I'll check the tsat tomorroe
Old Sep 21, 2014 | 09:55 PM
Norlael's Avatar
if the cap works then do coolant system pressure test, and cylinder leakdown. maybe the head gasket is good but you have a cracked sleeve/head. doesn't always show up on compression test.
Old Sep 21, 2014 | 10:08 PM
I agree, but it would show up on a block test.
Old Sep 22, 2014 | 10:23 AM
tony_2018's Avatar
Fish Twig
True.
Old Sep 22, 2014 | 02:16 PM
stupidhard's Avatar
i'll bet there isn't a thermostat. check your heater core? that's where I would look for blockage.
Old Sep 22, 2014 | 04:15 PM
tony_2018's Avatar
Fish Twig
Remove the cap and warm up the car, rev it a bit and see if the coolant is surging.
Old Sep 22, 2014 | 04:41 PM
Didn't get to tear into it today, work ran long. Will have results tomorrow
Old Sep 22, 2014 | 04:58 PM
tony_2018's Avatar
Fish Twig
All gravy.
G1tegra
Dec 23, 2018 03:15 AM
b00sted4dr
Oct 12, 2006 10:19 PM
Modern91Hatch
Jun 5, 2006 02:46 PM
blackexvtec
Jan 31, 2006 09:43 PM
97akwerd
Jul 30, 2005 08:43 AM
