Water in Rear of Del Sol
Under the cabinets behind the seats, I am getting water into the car after I wash it. Is this because the the drain tubes are plugged? Or maybe the sealer behind the black metal wall is deteriorating?
Any help is appreciated!
It's probably because your car is leaking, check your seals for deterioration, and your panel gaps for leaks, best way is to get inside your car and have someone spray the hose on it, find where it's leaking from and fix the real problem, it may mean adjusting your panel gaps or replacing old worn out rubber seals
You should also check the areas that have seam sealer...you know, bascially caulking for cars...i just had to redo a crapton of them on my 95 ej1. was getting water in the trunk solely from 4 bad seams. easy fix too.
I came across your old post, and wondering if you still can provide me procedure to prevent water from getting inside my trunk and also sloshes around in the rear of my cabin where the rear window is.
Thank you.
whokidd
22
Feb 24, 2011 02:36 PM
Mike Polinder
Jan 13, 2011 01:23 PM
Squallie
Sep 30, 2005 03:36 PM
NosCivic01
May 20, 2005 03:55 PM
