Trying to figure out what head gasket I need
So I completely am rebuilding my gsr. I had to bore out the cylinders .040. Should I get oem head gasket or a 81.5mm head gasket since I bored out a little?
Ehh I dont see any point in it though. Go look at how much .5mm actually is. The oem gasket has plenty of bore for an 81.5mm bore without protruding into the cylinder. If any did it would be .25mm worth of gasket material (assuming the gasket is a perfect 81mm)
BlackGSR
Feb 26, 2002 06:52 AM
Reason I know this is a had a 82mm GSR w/ an OEM HG. Mic'd and old OEM HG and 82mm it was.
