95 Honda Civic y8 swap won't start. PLEASE HELP
Old Sep 18, 2014 | 12:28 PM
bigcazzz's Avatar
Icon2 95 Honda Civic y8 swap won't start. PLEASE HELP
I just recently swapped a d16y8 into my 95 civic ex (d16z6)
I used the harness, intake, exhaust, sensors, dizzy, ps and ac. Everything whey fine until now. I try to crank it and all it does it turn over. I've checked the fuel filter it has plenty of fuel. Spark plugs are fine. It's set to tdc. Haven't tested it but seems to have good compression a friend of mine day drove it less then 6 months ago. I don't know what else to do. Any help would be greatly appreciated.
Old Sep 18, 2014 | 12:41 PM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 95 Honda Civic y8 swap won't start. PLEASE HELP
Foooooooooooooooo it could be numerous things...so I'll just spit out a bunch and see if anything catches or if anyone else can offer some suggestions. Spark plugs are fine as in? Is the spark white? Assuming there is spark at the plugs. Set to TDC how did you confirm? Could be off a few teeth. Definitely compression test it to see what the figures bring back, make sure you're at WOT. Spark plugs in the correct order?
Old Sep 18, 2014 | 12:44 PM
09chaplak's Avatar
Loves Tossing Salad
Which ECU are you using?
Old Sep 18, 2014 | 12:45 PM
bigcazzz's Avatar
Spun the crank to tdc matching the notch on the cover. Can gear was turned to where It says up at the top. And the button was pointed at #1. It was about half a tooth off. And I'm pretty sure. They do go 1342 correct?
bigcazzz's Avatar
The one from the z6.
Old Sep 18, 2014 | 01:08 PM
bigcazzz's Avatar
It's a p28 if I'm not mistaking.
Old Sep 18, 2014 | 04:02 PM
SuppDude1's Avatar
The old ecu will run on the y8 but vtec will not engage. You can rule ecu out of the question.
Old Sep 18, 2014 | 04:50 PM
HondaPartsHero's Avatar
Technical Hero
VTEC will activate with the P28. You used the y8 with its distributor or the Z6s?
Old Sep 18, 2014 | 05:35 PM
bigcazzz's Avatar
Z6 dizzy.
amoeba2315
Oct 31, 2024 07:55 PM
DjShotokan
Honda CR-V & Element
Jan 4, 2023 01:16 PM
hondaxnoob
11
Apr 27, 2013 12:41 PM
lilmisshonda
Jun 30, 2008 09:49 PM
geezer06
Oct 26, 2003 09:14 PM
