Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A2 swap to D17A
Old Sep 18, 2014 | 09:18 AM
Runamok81's Avatar
Default D17A2 swap to D17A
I have 01 Civic EX with a D17A2 motor. The headgasket is blown. I'm interested in swapping to a D17A JDM engine. I've got someone who can do the motor swap, but I need to watch out for pitfalls. If I drop my car off and this D17A motor at the shop, what should they be aware of?
Things I'm concerned about.
Immobilizer - If I use the original ECU, this shouldn't be a problem. Should it?
Sensors - Will the wiring harness of my current sensors hook up to the new engine?
Anyone have any useful links Guides, walkthroughs, or previous success story links?
Old Sep 27, 2014 | 07:30 PM
Sleeping Perfor's Avatar
Default Re: D17A2 swap to D17A
Well the 1 thing you have to watch it's for the immobilizer but if you decide to do it get the ecu/ pcm flash.
Old Sep 29, 2014 | 03:47 AM
Runamok81's Avatar
Did the swap. No issues so far. I am using the D17A2 ECU on the D17A.
Old Sep 28, 2015 | 12:01 PM
Mafiarose's Avatar
Hi... I was wondering if your swap was still successful? My son is needing to do the same thing, going from a D17A2 to a D17A. Wondering if we need to get a new ECU or harness or what? Your input would be greatly appreciated.
Old Sep 30, 2015 | 05:08 PM
jarret83's Avatar
I was just wondering what the benefits were of doing this swap? I'm new to honda but I am eager to learn!
Old Sep 30, 2015 | 06:15 PM
em2guy913's Avatar
Just swapping into a lower mileage motor that's all. Still the same motor as the D17a2
Old Sep 30, 2015 | 06:17 PM
em2guy913's Avatar
I'm on my D17a2 ECU also, but since you brought that up. Would it run into a problem in the long run?. JW
Old Sep 30, 2015 | 06:34 PM
jarret83's Avatar
Ok! That's what I figured. My 03 civic ex is in the shop for a mysterious oil leak that I cannot locate, after rear cam plug and what not. Thanks for the response!
Old Sep 30, 2015 | 07:20 PM
em2guy913's Avatar
NP!. Good luck with it.
Old Oct 13, 2015 | 05:20 PM
fujiwaratofu86's Avatar
Is it an auto or manual?
Old May 13, 2020 | 03:21 PM
Bearish28's Avatar
im planning on the same thing going with the jdm d17a and keeping the vtec on it since my a2 has it, which shouldn't be a problem still researching this. my a2 has a cracked block and head gasket but still runs which surprised me, but I now have oil in my antifreeze and in my exhaust so gotta get this swap done soon, and I am running a manual which hopefully will bolt on to the jdm with no issues as I will be doing this swap on a real tight budget, which includes a new clutch kit and flywheel plus motor mounts which my car needs badely
paulius907
Dec 28, 2018 01:04 PM
avalon boy
Sep 26, 2013 11:14 AM
chrisquin23
Honda S2000
46
Nov 23, 2008 07:48 PM
B18C1 '96 Coupe
Jan 1, 2003 05:13 PM
NOSpeed97
Aug 10, 2002 03:45 PM
