Gsr cam install.
Old Sep 17, 2014 | 10:29 AM
EF'GSRrr91's Avatar
Default Gsr cam install.
The head is removed off the block. After I removed the cams, I forgot what position they were in when I removed them.. If the cams get installed incorrectly they will bind up when I crank to start. I don't want that. I backed off the valve lock nuts.. So the cams are all ready to go in, but I need some advise to know what position to put them in the right way to open the valves. Would I refer to the firing order?
Old Sep 17, 2014 | 11:18 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Gsr cam install.
What in the world do you mean by "don't know which way to put them"? Each cam only goes one way. If you actually looked at the cams you will see they only go one way and are different cams...
Old Sep 17, 2014 | 11:41 AM
EF'GSRrr91's Avatar
I'm sure sure I can't just lay the cams in and torque down the caps.
Old Sep 17, 2014 | 11:49 AM
EF'GSRrr91's Avatar
Not saying Ima put them in backwards.
Old Sep 17, 2014 | 01:21 PM
cruizinmax's Avatar
Line up the timing marks on cam gears.
Old Sep 17, 2014 | 01:31 PM
EF'GSRrr91's Avatar
I understand. My problem is when I put my cams in place the lobes kinda touch the rockers and don't seat in properly for the caps to fully seat, meaning I must of accidentally turned the cams off about a tooth or two from tdc when removing them. So when the cams seat good in place decent, the tdc marks are off a tad bit... SO.. Do I just install them off a bit then once the caps are on and torqued just turn them counter clockwise till tdc marks line up?
Old Sep 17, 2014 | 01:32 PM
EF'GSRrr91's Avatar
Also, I'm doing this with the head off.
Old Sep 17, 2014 | 01:42 PM
cruizinmax's Avatar
It's normal for the cam to open some of the valves when installing them. It's pointless to installing the cams or worrying about timing them with the head off the car. You have to remove them to put the head on.
Old Sep 17, 2014 | 02:20 PM
EF'GSRrr91's Avatar
Omg wtf was I thinking! I got so excited to put this thing together that I spaced out and forgot about the head bolts under the cams. Thanks man, that just saved me unnecessary time.
Old Sep 17, 2014 | 02:22 PM
EF'GSRrr91's Avatar
But when I do get head on block. With the markings on tdc, the cams will still not seat in the head fully, meaning the caps won't seat fully... How should I go about that? Just put them in off a bit, torque down, then mark them up?
Old Sep 17, 2014 | 03:00 PM
wunfstgsr's Avatar
Loved
Community Favorite
Your welcome!
I just hope you know what your doing OP. And please remember to set the valve lash..
Old Sep 18, 2014 | 05:17 AM
DO IT ON ALL FOURS
Yes, that is a summary of exactly what you do.... Lube cams and journals, set cams in place, clock for correct timing mark position, set cam caps and rails on, start bolts by hand while alternating positions snug all caps down, and torque to spec. It is really THAT simple... You REALLY should purchase a repair manual.
Old Sep 18, 2014 | 06:59 AM
PyroProblem's Avatar
Its a good idea to rotate the crank so all the pistons are midway in the bore. Drop your cams in, torque properly and in the correct sequence, time everything, and set your valve lash. Get a service manual. Everything you need to know is there.
Don't rush things. Especially if it's your first build. Its easy to miss something or install something incorrectly and ruin the entire engine. Good luck!
threehonda
K Series
Dec 20, 2009 06:37 PM
jdm ek9 101
Sep 13, 2006 04:46 PM
94b16teg
Aug 11, 2006 09:11 AM
quis23
Aug 26, 2004 09:59 AM
camp1320.com
Dec 3, 2002 08:53 PM
