Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 civic power window issue
Old Sep 16, 2014 | 07:54 AM
brent_si's Avatar
Default 06 civic power window issue
I just bought a 06 civic ex. The passenger window will not go down from either the driver master switch or the passenger switch. I know the switches go bad from what i've seen. I have done a bit of research but I can't find but the exact answer I need. Does it sound like a switch issue or a window motor/regulator?
Seems to me if it was a switch the passenger switch would still work.
Old Sep 16, 2014 | 04:35 PM
97emsedan's Avatar
Default Re: 06 civic power window issue
Can you check for continuity at the switch, and if it is good, check the motor. Most likely it is moisture corrosion at the switch contacts.
Old Sep 18, 2014 | 09:11 AM
vladd's Avatar
You've probably already checked, but the passenger window isn't locked out on the driver's door panel, is it?
builthatch
May 29, 2012 09:38 AM
Bayhustle81
Aug 31, 2009 01:44 AM
hondapwr
Jul 17, 2009 05:30 PM
ChicagoMike
Mar 14, 2006 08:07 AM
