Help Help Help plz P0344
My Standard 2005 Honda civic ex is showing a code P0344 Camshaft Position Sensor Circuit Intermittent.I restart the code but it came back on.I can start the car and it will rev to 5000 no problem, then about 5 seconds later it goes back to hitting a limiter and wont go past 3500 rpm.Can someone plz Help me out on this.lmk if I have to change any sensor...thank you
What it's happening your car it's going into limp mode.
Please do this step by step.
1. Take the ground from the battery andvthe ECU fuse under the hood.
2. Remove the MAP sensor and get a new one.
3. Replace the MAP sensor with a new one.
4. Put the ground wire into the battery and crack it 3 times.
5. Now take the ground out and put the ECU fuse back in his location.
6. Now put the ground into the battery, and crack it.
Let me know if it work if not I will the best I can to help. By Sleeping Perfor
DK4200
Honda Civic (2001 - 2005)
Nov 16, 2018 11:27 AM
