Should this quiet my car down?
Here's the exhaust setup currently:
2.5'' High Flow Cat
2.5'' Crushbent Piping
2.5'' Thermal Straight Thru Muffler
The car gets pretty loud. Higher RPM...gets pretty damn raspy and low rpm it's a lower tone..but still quite loud.
So I'm thinking...what if I put a stock..say...gsr or si muffler? That should quiet it considerably right? I know top end will suffer..but when I go to tracks...I'll probably run open header...or do some exhaust cutout part.
Main reason I wanna do this is cops in CA are pretty ****. The car itself looks stock...but the sound would give it off. And if they pull me over for the exhaust..i know the hood will be popped open also. Then the engine swap with no BAR certification, no CARB EO#s, blah blah blah...it'll just be a hassle
So you guys think the muffler would do the trick? Or maybe just a resonator?
-Rod
2.5'' High Flow Cat
. So you guys think the muffler would do the trick? Or maybe just a resonator?
-Rod
doesn't thermal offer a "silent" or whatever modification to any exisisting exhaust if u send it back to them? you may want to ask the Forced induction crew since many of them run thermal exhaust.. but I would switch to either a ITR or CTR exhaust both are basically 2 1/4... or order an older RSR series from Turboimports..but your car is TURBO correct since u are running a 2.5 all the way.. if not just switch it over to a GSR if u can't find anything else...I currently run 2 1/4 cat.. 2 1/4 piping mandrel to a stock dx exhaust I so hate it so I'm getting a ctr stock muffler to bolt up
no..not turbo...all motor setup
b18c1
injen race cai
jg header ib modified 2.5'' collector
and the rest of the exhaust setup i posted earlier.
b18c1
injen race cai
no
for the thermal anymore
I have an Apexi worldsport
. It's very quiet and will give you a little better performance than a si or gsr exhaust.
i wanted to put a stock si muffler on my car w/ the 2.25 piping but the guy at the muffler shop said it cant be done
whatever, i sold the muffler anyway.
? whatever, i sold the muffler anyway.
then why the 2.5 If you went with a 2 1/4" you would drop sound and gain more needed back pressure 2.5 is kinda big for all motor
um no its not.......i even heard some all motor guys going with 3"
Here, read this: http://modernmusclecars.net/articles...tdynamics.html
i'm running a jdm ITR header, carsound high flow-cat, 18" resonator, 2.25 custom piping and a 00 civic si muffler. its quiet, looks stock, sounds sorta like stock, my intake is louder that it. i'd rather loose a little bit top end than get a ticket for modified exhaust. IMO
wassup Rod, its joseph, get an ITR muffler and a resonator
92cx b16a
Hey wussup Joseph. Dude...I would get an ITR muffler but they're hard to find and overpriced.
I don't wanna get an ES Oval simply because it'll still be loud. Straight thru muffler...same as the one i have now. Yea I know...the ES looks stock..but mine doesn't look flashy either. I had a 2.5'' tip welded on...so it looks like a puny muffler.
I guess I can try getting a long resonator...hopefully it'll work...I'll just be pissed if it doesn't
. Will have to pay twice. Here's the exhaust cutout i wanna get:
http://store.summitracing.com/partdetail.asp?part=828
Whatcha guys think?
-Rod
. Will have to pay twice. Here's the exhaust cutout i wanna get:http://store.summitracing.com/partdetail.asp?part=828
Whatcha guys think?
-Rod
no
I feel you! Thermal
I feel you! Thermal
THERMAL KICKS ***!!!!!
i was talking about him not having any
for thermal...what didnt you like about it?
DOHChatchGUY
Dec 31, 2007 10:31 PM
se93
Aug 25, 2002 01:37 AM
