b16a2 rev limit
So, according to my research, b16's revlimit should be around 8,200. My b16a2 only goes up to 6,000 though. I've been reading that it could be distributor (i think?). What else could it be though? Just tune ecu? Also it's running obd2a to obd1 p28. It's a 96 civic ex. Thanks in advance for any help.
Cool Cool Island Breezes. BOY-EE
I'm guessing this is a chipped P28?
You may have a clogged VTEC solenoid or it may be unplugged/have a bad connection.
Or there's something wrong with the ECU. The ECU dictates rev limit...not the engine.
So, i cleaned out the vtec solenoid. it had little metal shavings in there. Drove around and then tested but no luck, still bogged at like 6,200 - 6,400 rpm.
When i swapped in my b16, i swapped the harness with it. Only 1 o2 sensor was plugged up because si harness has 1 plug vs d series having 2. Si ecu gave no code for the 2nd o2 sensor.
It also might be masking another problem. Like I said, halfassed work never ends well. Fix everything, not just what you feel like fixing.
O2 sensors don't set rev limits. The ECU ignores both of them after a certain throttle %. They don't affect VTEC either.
This has to be another troll thread. OP is being dense on purpose.
