help
Old Sep 8, 2014 | 05:11 PM
mateen123's Avatar
Default help
I got a 1999 civic hatchback with an b16a swap. When I drive the car just starts jerking. Something like 2 step but while driving. Also one other thing I replaced my intake manifold wit an obd0 engine the plugs are the same. So I just used that. Let me know if that is the problem
Old Sep 8, 2014 | 06:06 PM
halfkoreanboy's Avatar
Default Re: help
How are the spark plugs ? I had a civic that jerked like crazy and i changed the spark plug and it went away lol.
Old Sep 19, 2014 | 08:56 AM
Eg5ir1's Avatar
Default Re: help
As HALFKOREANBOY said, check your plugs for any wear. That might cause misfires.
Does the car jerk at a certain rpm if so check your tps since it might have a dead spot. This usually cause jerking at a certain rpm no matter what gear you are in. If this is the case and you have a multimeter you can check your tps for a dead spot.
Old Sep 19, 2014 | 10:09 AM
purgat0ry's Avatar
Default Re: help
Ignition and timing are my suggestions.
Check FAQ (Look at my sig) and you will find guides for checking both of those.
corys_ej8
Sep 2, 2011 06:12 PM
corchado85
May 20, 2007 06:20 PM
Jaydeep
Sep 14, 2004 09:17 AM
sporkcrx
Jul 3, 2004 07:59 PM
JDM-Vic
Feb 23, 2004 11:29 AM
