B18b1 with gsr trans
Old Sep 7, 2014 | 03:06 AM
CivicJordan's Avatar
Default B18b1 with gsr trans
What's up guys, the other day I pulled out a b18b1 auto out of my 94 integra. I'm planning on getting a gsr transmission and dropping the whole swap in my 96 civic EK. The car previously had a d14 in it. What mounts, and linkages do I need? Can I use the same wiring harness out of the integra for the gsr tranny?
Old Sep 9, 2014 | 06:44 PM
stupidhard's Avatar
Default Re: B18b1 with gsr trans
the engine wire harness is for obd1- good
its an automatic- three of the connectors will not be used in the swap because the manual trans doesn't need them. you will have to do some searching and figure out what wires you may need to run/re-pin at the shock tower plug point.
there is a list of components that you need to complete the swap in the faq and sticky area.
this is all the info I or anyone else is willing to spoon feed to you (not trying to be a jerk) so do some homework.
if we give you all the answers, you may get your swap done, but you wont totally understand what or why you did what you did.
-chris
Old Sep 20, 2014 | 03:48 PM
HiProfile's Avatar
Mounts: 78 Citroen
Linkages: 66 Chris-craft, beware 67 used cables
Harness: Boeing 707
Seriously? This is *the* most common swap in the world, there are >1000 write-ups on the internet. Click the damned link below:
Let me google that for you
Old Sep 24, 2014 | 10:16 AM
Trey's Avatar
25 Year Member
Use your EK engine harness, wire in the Vtec stuff.
From Katman:
luckramer
Feb 27, 2019 03:34 PM
gsrbuilt35r
12
Oct 6, 2010 10:57 AM
1990civic4door
14
Apr 19, 2010 02:25 AM
bouttobeout
Mar 12, 2004 06:04 PM
JV
Oct 23, 2003 07:07 PM
