Fuse #44 fi em keeps blowing
My car was running fine until i decided to change my battery due to smelling like rotten eggs, i also found out that i have to change my alternator, when i put the new battery in fuse blew causing my car not to turn on i can get it to crank but not turn over.
this is what i've done so far i supplied power to main relay with test leads and got continuity on all the pins that needed to be tested from a walk thru that i seen here. my relay is good
i disconnected main relay and the fuse does not blow, i also jumped terminal 1 to 7 to check fuel pump and turned on,
I know i have a short and have no idea were to start looking any feed back would help ive researced and no luck
I can't help but wonder what kind of car you have?
I once had a Desoto that exhibited the exact same symptoms as yours.
On my Desoto it was the rope rear main seal leaking on the generator causing a short.
Jerkface38
Honda Civic (2001 - 2005)
Mar 8, 2013 03:56 PM
