Oil Catch Can - Theoretical Vacuum Issues
Old Oct 31, 2002 | 09:43 PM
IN VTEC's Avatar
Default Oil Catch Can - Theoretical Vacuum Issues
I'm kinda hesitant to install my SRR oil catch can. I'm worried that with the longer hosing, the PCV valve won't see the proper vacuum to open it fully and/or for the proper durations.
Does anybody know if the vacuum drop associated with running an oil catch can and hosing is enough to hinder proper crankcase ventilation? -I would be installing the catch can right in front of the battery/EVAP canister, just below the stock STB. Hosing is about 1.5' to and then 1.5' from the catch can.
I need to get a vacuum gauge and some t-fittings to test this for myself, but if anybody is supportive or disapproving of this theory, let me know what you think.
Old Nov 1, 2002 | 02:49 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Oil Catch Can - Theoretical Vacuum Issues (IN VTEC)
you are thinking about it too much
the pressures within the block will open the valve
stan
Old Nov 1, 2002 | 04:15 AM
92sleepR's Avatar
New User
I wouldn't worry about it. If you were mounting it like 10' away it might be an issue but as long as the hoses are sealed properly you will be fine. The SRR can is nicely made. I'm thinking of getting one myself.
Mike
Old Nov 1, 2002 | 05:27 AM
brcivic411's Avatar
Default Re: Oil Catch Can - Theoretical Vacuum Issues (92sleepR)
Mike
Set O' Nines
Oct 30, 2012 07:49 PM
555R
May 19, 2004 10:58 AM
b18c-93
Nov 28, 2003 06:29 PM
MADEINIRAQ
Jun 1, 2003 06:51 PM
andrew dc
May 4, 2003 07:06 AM
