oil burn under vacuum
Old Jun 1, 2003 | 06:43 PM
MADEINIRAQ's Avatar
Default oil burn under vacuum
well.. after my ITR cam/ intake manifold/ portflow valvetrain install i burn oil unter vacuum. (idle and after long engine braking)
I did install new valve seals but I may have ruined them because I tapped them on with a 3/8 ratchet extension and a hammer.. i didn't tap too hard but i guess it was too hard since it burns oil.
After searching and reading all the posts.. I think its the valve seals but was seeing if anybody has opinions.
PCV valve is good.
Old Jun 1, 2003 | 06:47 PM
Turbogixxer's Avatar
Default Re: oil burn under vacuum (madeiniraq)
does it burn oil when you first start it up? I mean when you let it sit for a while, does smoke (blueish) come out the tail pipe? if so, then the valve seals are bad.
Old Jun 1, 2003 | 06:51 PM
MADEINIRAQ's Avatar
Default Re: oil burn under vacuum (turbogixxer)
yes...
Set O' Nines
Oct 30, 2012 07:49 PM
Takumi Fujiwara
Dec 3, 2005 11:57 AM
opiumdaze
Apr 23, 2005 02:20 PM
Sh4rky
Apr 16, 2002 06:45 AM
Toda Party
Feb 13, 2002 10:25 PM
