Vtec not working
Old Sep 3, 2014 | 11:17 AM
Em1Kleber's Avatar
Default Vtec not working
any idea why my vtec doesnt kick in all the time? Its b20b4 with b16 head, replaced solenoid with one i had before, still same problem, oil level is fine, coolant is fine, once i drive it for awhile it stops kicking in
Old Sep 3, 2014 | 01:46 PM
m4xwellmurd3r's Avatar
Sounds like its not grtting enough oil pressure. You should have no less than 50psi@3k rpm. The fact that it takes a while (im guessing 15-20min) is most likely due to the oil viscosity thinning as it reaches operating temp
Old Sep 3, 2014 | 03:02 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Vtec not working
https://honda-tech.com/forums/showth...2135&styleid=2
Old Sep 4, 2014 | 10:26 AM
VeeSykkz's Avatar
I second oil pressure loss. If it works early, the system works. Sounds like external factor like pressure loss. How is the pump?
tobster
Mar 13, 2011 12:32 PM
4door hobo
Jul 30, 2007 07:53 PM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
Turbocivic94
Jun 10, 2003 07:11 PM
zdr262
Oct 23, 2001 09:29 PM
