radiator fan not working
Old Sep 3, 2014 | 09:25 AM
CrossCountry's Avatar
Icon2 radiator fan not working
the fan motor is good.
the relay is good.
fuses are good.
tried to use a paperclip in the ect sensor and that didn't turn the fan on.
how do I test the electrical clipped thing between the motor and the relay? (by the coolant overflow tank)
or, maybe it's the wiring going to the relay, or from it???
should the radiator fan turn on automatically if the a/c or heater is on? or just after the antifreeze is hot? How hot? I've run the car for 10 minutes it still doesn't come on, and heater is HOT.
also, there is no thermostat... how do I know if the antifreeze is circulating or not? It just looks like it's vibrating.
trying to buy thermostat... oreiley's says the base is round. on hondapartscheap.com it looks oblong. which is correct???
thx
95 honda civic, with a 96 honda civic engine.
Old Sep 3, 2014 | 10:38 AM
KevinEF7's Avatar
Default Re: radiator fan not working
10 minutes is surely not enough from cold especially since you are not running a thermostat, expect it to take 25 minutes to come on, even longer if you are running the heater in the process
Old Sep 3, 2014 | 10:58 AM
thx.
So, the heater doesn't automatically turn it on.... hmmmm.
Does the a/c automatically turn radiator fan on???
Old Sep 3, 2014 | 03:05 PM
HondaPartsHero's Avatar
Technical Hero
Which ECT sensor did you jump?
Old Sep 3, 2014 | 06:03 PM
http://www.hondapartscheap.com/auto-...hermostat-scat
on this diagram, I used a paper clip in # 13, fan didn't turn on, so I tried # 12... still didn't turn on.
the reason I think the relay is good is because if I put the fan relay in the blower relay slot, the blower still works. However, the two relays have different numbers on them, so it's possible that they're made differently inside??? I think that's unlikely though.
I took out the radiator today, flushed it & cleaned the gunk off the outside, re-installed and flushed through the engine. Checked a thermostat, it works, installed it.
Old Sep 4, 2014 | 10:24 AM
VeeSykkz's Avatar
Yes, ac always overrides fans. Install a tstat, check coolant level because low coolant won't touch temp switch, replace coolant fan switch.
Old Sep 5, 2014 | 07:11 AM
So, when I turn on the ac, should BOTH fans turn on, or just the fan by the compressor???
Old Sep 5, 2014 | 12:12 PM
holmesnmanny's Avatar
Both always run simultaneously when the ignition is on and/or engine is running.
Old Sep 5, 2014 | 09:46 PM
VeeSykkz's Avatar
no they dont manny. Only if your fan relay is hardgrounded and always running.
one fan is radiator, one is ac condenser. They both cycle. one with temp, one when AC calls. I forgot you have a civic and not a huge wide radiator like my cars.
Old Sep 8, 2014 | 07:00 PM
Well, after driving car for 25 minutes, I opened the hood and expected to see the radiator fan running, but it wasn't. wait, wait, wait... after five more minutes the radiator fan finally came on... for about 5 seconds. Then went off again. So I guess the 95 Civic just doesn't need the fan very much.
I never could get a paperclip in any sensor to turn on the fan even though the fan does work.
Old Sep 9, 2014 | 01:24 AM
VeeSykkz's Avatar
lol theres a reason it only needs half a radiator.
Old Sep 10, 2014 | 09:34 AM
lol
thanks for everyone's help.
Old Sep 11, 2014 | 07:58 PM
VeeSykkz's Avatar
any time. Glad we helped you learn something.
gitarman2
May 26, 2013 03:58 PM
Fighterinsnatch
14
May 26, 2007 08:18 PM
Dual_Phart_cans
33
Jul 25, 2005 09:12 AM
hybrider
Jul 23, 2002 08:21 AM
joel
Oct 17, 2001 09:54 PM
