Fan issue, please help!
Old Sep 1, 2014 | 02:51 PM
Jnkbortka's Avatar
Default Fan issue, please help!
I have a 1992 Prelude, and the fan blows, but it is not very strong. I took the blower motor out, and there was tons of **** in it, but when I put it back in, it didn't really improve the strength of the fan. could it be that I need a new blower motor? could there be a clog in the vent somewhere?
Thank you!
P.S. There is no A/C, if that makes a difference
Old Sep 2, 2014 | 05:19 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Fan issue, please help!
the blower system needs clear passage in and out. typically it's due to a clog/filter issue, see if there's a noticeable difference in airflow between circulated and vented modes (with the windows down, then windows up on each). if the airflow is low in either mode, verify you have proper voltage, replace the relay, then replace the motor.
Old Sep 4, 2014 | 10:38 AM
VeeSykkz's Avatar
Or blower motor resistor?
Old Sep 4, 2014 | 03:22 PM
holmesnmanny's Avatar
Its best to just replace both while you're in there.
HondaPartsHero
Honda CR-V & Element
Aug 8, 2013 02:08 PM
Bender C/F
Feb 12, 2010 07:46 PM
092eg6
Aug 8, 2009 10:30 AM
eg:R
Mar 26, 2008 11:05 AM
