Brake indicator on dashboard stays on
Old Sep 1, 2014 | 08:35 AM
Pulang90EF's Avatar
Default Brake indicator on dashboard stays on
Hello everyone!
I am having issue with the "BRAKE" indicator on the dashboard staying on. I was driving one day then it started flashing then it went solid. Any suggestions?
Old Sep 1, 2014 | 08:40 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Brake indicator on dashboard stays on
um,check your brake fluid
Old Sep 1, 2014 | 08:59 AM
24TEN's Avatar
PHANTOM MENACE
Old Sep 1, 2014 | 09:13 AM
Pulang90EF's Avatar
Just checked the fluid & it's on the "MAX" line. Sensor connections seem to fine.
Old Sep 1, 2014 | 09:37 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The BRAKE indicator lamp can be caused by either the brake fluid level switch or the parking brake switch.
Under the hood, disconnect Black Connector C310. If the BRAKE lamp goes out, the issue is related to the brake fluid level switch; the switch may be stuck closed when it should be open (if the fluid level is okay).
Old Sep 1, 2014 | 02:39 PM
Pulang90EF's Avatar
U guys rocks! It was the brake fluid switch..it was stuck. I re seated the connections & replaced the cap cover back on..... No more stuck brake light...!
Thank you thank you thank you!
Old Sep 1, 2014 | 05:47 PM
Daily90efsedan's Avatar
Good to know
Mveilenstein
Jul 27, 2018 11:25 AM
bradtricker
11
May 19, 2009 01:32 PM
tommyoc
Feb 22, 2007 08:54 AM
peshte
Aug 26, 2005 03:13 AM
96 Ls lnTeG
Mar 19, 2004 04:46 AM
