Civic Type R P0420 code
Old Aug 30, 2014 | 07:36 AM
Housey's Avatar
Default Civic Type R P0420 code
Have a civic type r 2002 135k on the clock. Fitted an aftermarket cat, and 2 new sensors cleared the code. Now after 3 days the code has unfortunately returned which has gave me a real headache.
When the cat was installed plugged in a laptop with diag software which again showed mirrored fluctuating signals in both o2 sensors in closed loop mode.
Any Ideas out there
Old Sep 1, 2014 | 07:25 AM
SickSi99's Avatar
Default Re: Civic Type R P0420 code
I'd be willing to guess the aftermarket cat is what's causing your ECU to freak out and show a deficiency in your O2 sensor. You might need a defouler to move it away from the stream a little bit.
Old Apr 3, 2015 | 02:04 AM
Housey's Avatar
Yes I used an o2 sensor spacer right angled, code no longer appears and car appears to run a lot better.
Cheers
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
impr323
Jun 21, 2005 05:29 PM
danteisme
Mar 16, 2005 07:01 AM
py1188
May 17, 2004 06:37 AM
