Timing belt job - Cam & Crank seals question
Old Aug 29, 2014 | 12:34 PM
steadysupreme's Avatar
Default Timing belt job - Cam & Crank seals question
Hi, i am doing my timing belt job, while im there, what should i change? Also, would want to do a little preventative maintenance as well. Here are the parts i changed and going to change:
Changed within 15 months:
distributor assembly
cam plug
wires
spark plugs
thermostat
serpentine belts
Going to change:
ordered Gates TCKWP247
-timing belt, tensioner, waterpump and gasket
14516-PR4-A00 tensioner spring (necessary?)
17130-PM6-G01 PCV
91213-PR3-004 cam seal x2
crank seal
16010-ST5-E02 fuel filter
12341-PR3-000 valve cover gasket
12342-PT2-000 tube seals x4
Am i missing anything else? And what's the part number for crank seal? Thank you very much in advance.
And most likely ordering through https://www.acuraautomotiveparts.org
Old Aug 29, 2014 | 01:15 PM
Default Re: Timing belt job - Cam & Crank seals question
is hondapartsunlimited legit?
Old Aug 29, 2014 | 01:36 PM
purplepassiongsr's Avatar
Yes but delray acura is usually cheaper in my experience.
Old Aug 29, 2014 | 02:26 PM
I will check with that now. Thank you.
Old Aug 29, 2014 | 02:36 PM
checked Delray, they have everything other than the fuel filter. And compare to acuraautomotiveparts, they are around $6 cheaper.
Old Aug 29, 2014 | 03:20 PM
94rs-turbo's Avatar
I'll still be cheaper, not sure about shipping to Canada though
Old Aug 29, 2014 | 03:25 PM
You can ship to my WA address. Can you quote me on the above stuff shipped to WA? Thank you in advance.
Old Aug 29, 2014 | 07:28 PM
IN VTEC's Avatar
The timing belt is the only part number that doesn't cross-reference to the honda catalogue. The same parts from Honda re cheaper. I'd order everything from hondaautomotiveparts.com since you're getting the timing belt locally.
Old Aug 31, 2014 | 09:58 AM
94eg!'s Avatar
#1 Super Guy
Loved
http://www.oemacuraparts.com/
^Sells both Honda & Acura parts. The Acura counterparts are always a few cents cheaper. Use coupon code SWOOSH to get half off shipping price on orders over $100. These guys are in Arizona and always have great customer service. Takes a few days extra if they have to get Honda specific parts from the neighboring Honda dealer.
Old Aug 31, 2014 | 12:59 PM
I ordered thru www.acuraautomotiveparts.org since i can't wait. And www.oemacuraparts.com don't offer the fuel filter for some reason.
Car is apart, can't wait to put it back together.
Old Aug 31, 2014 | 02:02 PM
94eg!'s Avatar
#1 Super Guy
Loved
Of course they have the fuel filter: #1 16010-ST5-E02 $22.61
http://www.oemacuraparts.com/auto-pa...el-pipe-2-scat
Old Aug 31, 2014 | 11:29 PM
sorry my bad, it doesn't have 91213-PR3-003 (crank seal) is what i meant.
When i put 91213-PR3-003, it always shows as 91213-PR3-004.
Old Sep 1, 2014 | 07:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
http://www.oemacuraparts.com/auto-pa...-strainer-scat
Old Sep 2, 2014 | 12:10 AM
what the heck...strange. Cause yesterday when i add #17 to cart, it will become 91213-PR3-004.
But now i just tried, it's on its own now.
Old Sep 2, 2014 | 09:26 AM
94eg!'s Avatar
#1 Super Guy
Loved
If I do a raw search for that part#, it does change it to 004. No idea why. If you have questions about stuff like that, contact them. They usually respond same day.
Old Sep 2, 2014 | 11:04 AM
Mccormick009's Avatar
Sorry to thread jack but felt it was appropriate. I am doing my valve cover gasket, spark plug seals. Should I do anything else at the same time? I am hearing about cam seals....any links to a good DIY?
Old Sep 2, 2014 | 11:17 AM
Update. I plan to do the exhaust cam seal since I will be in there. Should I worry about the intake cam seal behind the distributor? Do these go bad?
Car has 171,000 miles
Old Sep 2, 2014 | 11:29 AM
94eg!'s Avatar
#1 Super Guy
Loved
Personally I wouldn't touch any seals if they aren't actually leaking. They can run forever without leaking. Conversely, you could screw up the install and cause a leak with a brand new seal.
As for the distributor, it's got an o-ring. sealing it to the head. Very easy to replace. Again I wouldn't bother if it wasn't leaking.
I've got a 89 CRX at 226k miles with original crank seals in it (knock on wood).
Old Sep 2, 2014 | 02:33 PM
Sounds good. The intake side doesn't look bad from what I can see but I am leaking oil out of valve cover and there is a lot of residue around where the exhaust cam cap is.
00crv
Honda CR-V & Element
Dec 19, 2011 04:11 PM
TOO MUCH TORQUE
Apr 18, 2011 06:27 AM
Adj
Jul 14, 2009 11:07 AM
don24
Jan 10, 2006 02:40 PM
Eluder200K
Jan 27, 2003 01:50 PM
