90 integra wont start??
Old Aug 29, 2014 | 11:45 AM
evan221's Avatar
Default 90 integra wont start??
car ran and drove fine before it was parked for a few mths.
the car just turns over. already changed the main relay with a new one and battery.
the car has a working aftermarket alarm and ive checked all the fuses which are good.
what else can i check?? and is there a way to check the fuel pump direct?
Old Aug 29, 2014 | 02:16 PM
91wagonman's Avatar
Default Re: 90 integra wont start??
Hi. Have you pulled a spark plug wire to actually test the spark? A cheap spark tester is usually less than $5, or you can do it the old-fashioned way of sticking a plug into the wire and laying it against something metal on the engine...when you crank the motor, you should see spark.
Old Aug 29, 2014 | 02:37 PM
mike_1212's Avatar
Turn the key to the "on" position and listen for a buzzing for about 2 seconds.. if you hear it then pump is fine and priming. If not check fuses and relay.
Old Aug 29, 2014 | 06:36 PM
evan221's Avatar
yes no spark just changed the cap and rotor and it tried to start/misfire and back to just cranking
Old Aug 29, 2014 | 06:40 PM
evan221's Avatar
all fuses are fine/main relay is brand new/cap rotor brand new/batt new/check plugs and there good
i even tested the pump direct with my battey charger. im stumped because the car was running fine before parked.
Old Aug 30, 2014 | 03:35 AM
mike_1212's Avatar
Sounds like a bad igniter.... or module... test to see if you have power coming into the dizzy..... just search the forums for dizzy test guide. It will walk you through the process step by step... and which wires are which. I just cant remember all of this stuff for so many different engines... lol
Old Sep 1, 2014 | 06:01 AM
evan221's Avatar
have power at the dizzy
Old Sep 1, 2014 | 08:29 AM
fcm's Avatar
fcm
Old Fart
Also check for power at IGP1 and IGP2 at the ECU/ECM with ign. switch in both the run and start positions, [run and start positions also applies to power to distributor].
If powers are good, as mentioned, check ICM, [igniter] and coil. 94
Old Sep 1, 2014 | 12:22 PM
evan221's Avatar
is this what i would need?
http://www.ebay.com/itm/NEW-IGNITION-COIL-JDM-FITS-VARIOUS-VEHICELS-30510-PT2-006-TC-08A-UF-89-C1158-/131133510694?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3AIntegra&hash=item1e882a9426&vxp=mtr
Old Sep 2, 2014 | 09:47 AM
evan221's Avatar
ttt
Old Sep 2, 2014 | 09:56 AM
mike_1212's Avatar
Dont buy anything until you know what you need... otherwise youll end up spending lots of money and you wont solve your problem.... test test test. There are many things that can cause your problem... only 1 of them is acctually whats causing it... diagnose and test to find the one that is the cause and then thats the one you buy and replace..
Old Sep 2, 2014 | 12:54 PM
evan221's Avatar
ive stated above. what else is there to test?
Old Sep 2, 2014 | 01:07 PM
mike_1212's Avatar
Test ignition system at the ecu. Send ronj@ht a pm, he can tell ya which wires they are are. My pc is in the middle of being rebuilt so i dont have my schematics avail... you want to test ignition sys leads and then of course the ecu itself... ronj is a great guy and im pretty sure he has a schemaric handy and can tell ya which pins/ wires you should be testing...... did you clean and tighten all grounds yet? (Dont assume they are good make sure)
Old Sep 2, 2014 | 01:10 PM
mike_1212's Avatar
One more thing did you check mechanical timing? Is the rotor under the cap actually turning?
Old Sep 3, 2014 | 07:18 AM
evan221's Avatar
yep car was 100% fine before parked up. my hondata ecu is working fine
all the grounds were checked and re cleaned. timming is fine/ rotor turns. is there a way to direct check the coil to see if it sparks?
i know the dizzy is getting power
Old Sep 3, 2014 | 09:54 AM
m4xwellmurd3r's Avatar
You know how I tested a distributor to make sure it worked? Take it off the car, plug it into the harness, throw a set of wires and plugs on it (grounded plugs on the valve cover) disconnected my resistor box to ensure I didnt spray fuel. Turned the ignition switch to run, then rotated the distributor shaft by hand. Got a nice steady spark spark spark as it rotated.
I didnt wanna hook everything up and have the car fail to start with no obvious indicators of the issue. And I had cit the obd1 plugs off and swapped them to obd0 plugs for my obd0-obd1 swap. (It makes going back to stock easier just in case something happens)
Old Sep 6, 2014 | 12:31 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
my moneys on a coil or ignitor. also check the small wire in the distributor going from the coil to ignitor. seem it corrode apart before. honestly i never figured out a way to narrow it down further from a coil and/or ignitor going bad, without swapping parts. i mean theres no codes for them, and i don't think there's really a way to test either with a meter.
actually yea, i think you should be able to test the coil somehow with a multimeter. anyone know for sure?
94hatchy
21
Nov 13, 2010 05:23 PM
rtuner
Jul 6, 2010 05:09 AM
Cameron60
Feb 19, 2009 10:22 PM
projsectEF
Jun 9, 2006 06:00 PM
skata89
May 21, 2006 03:32 PM
