Condensation In Headlight Assembly
Old Oct 31, 2002 | 06:54 PM
brownman72000's Avatar
Default Condensation In Headlight Assembly
My left housing has condensation and a little bit of water in it. It has been there for a while now and isnt drying out. Im guessing that the seal is not tight. Has anyone had this problem before. Does the headlight housing come out pretty easily? Im thinking of taking it out and then resealing even though I have no idea how to do that? Any suggestions? Thanks!
Old Oct 31, 2002 | 06:55 PM
BDiddy's Avatar
Default Re: Condensation In Headlight Assembly (brownman72000)
I have the problem in my rear tail lights. Im thinking about getting them under warrenty if I can. How old is the car?
Old Oct 31, 2002 | 07:31 PM
Bbasso's Avatar
IF you take out the rear light that has water in it You will see the gasket the should be protecting from water. If you see that the gasket is dried out and brittle then replace, OR if its torn replace (duhh) Other wise there is not much else to cause the leakage Unless the light itself if craked or broken...
That Gasket is a dealer Item btw.
Old Nov 1, 2002 | 07:51 AM
mstewar's Avatar
good luck, and let me know how it goes trying to reseal it.. i bought a new headlight assembly to fix mine..
Old Nov 1, 2002 | 07:55 AM
RTW DC2R's Avatar
Default Re: Condensation In Headlight Assembly (mstewar)
I had water in my head lights at one point. What I did was take out the bulb over night and let air it air dry overnight. It pretty much dried up completely I hasnt seemed to be a problem since. also, if you leave your lights on while driving(even during the day), the heat will help evaporate some of the moisture. HTH
Old Nov 1, 2002 | 08:01 AM
reefer_bob's Avatar
Default Re: Condensation In Headlight Assembly (RTW DC2)
Take the bulb out, get a hair drier, point the hair drier in there for an hour or so... Check the integrity of your seals... put it back together!
That's the easy fix.
Old Nov 1, 2002 | 09:15 AM
NSX Bob's Avatar
New User
If the car is still under warranty, Acura will replace it w/ what should be no problem. I've been down this road, and rather than dick around w/ it I let Acura replace it. That's what the warranty is for.
Old Nov 1, 2002 | 02:41 PM
Default Re: Condensation In Headlight Assembly (Itr00-1374)
I wish I could but the cars got 90k on it!
Old Nov 1, 2002 | 04:43 PM
typer.org's Avatar
steve has the same problem on his car.
take a look at the car on the left and look at the drivers side headlights.
water and condensation in it.
Old Nov 1, 2002 | 05:13 PM
(__________)'s Avatar
Default Re: Condensation In Headlight Assembly (typer.org)
yea that makes me mad thats just another excuse for my front end conversion
liyan1430
Honda S2000
Apr 21, 2012 02:34 PM
Coupe-R
12
Jul 9, 2006 12:51 AM
TehMoonRulz
22
Apr 22, 2006 04:16 PM
Backk InTheDA
Jan 6, 2006 07:06 PM
vtecteg00
Mar 6, 2005 10:37 PM
