95 Civic Eibach Rear Sway bar with PWJDM endlink fitment problem
I have a 95 Civic EX Coupe. The car had no stock rear sway bar so I bought the 17mm Eibach rear sway bar with the Password JDM ultimate end links. The problems is the sway bar seems like it is wanting some kind of bushing. Call Eibach and they said that I'm suppose to reuse the stock bushing and end links or a blox adjustable variant. Looked around Autozone/O'reilly online and have not been able to find such a bushing. Has anyone else encountered this problem with this set up or have a possible fix action?
Fix Action: Found Function 7 bushings
Function7 10mm Rear Sway Bar Bushing Set (4) F7-F7BRS10 - King Motorsports Unlimited, Inc.
I have a stock 22mm rear sway and I'm using function 7 endlinks not all end links work with some sway bars.. I was going to get the password ones. But I was told not to because of the very problem your having
Go to any OEM Acura parts website, enter in any Integra model year from 94-01, select Rear Lower Arm. From there you'll see the bushings and collars you need.
52312-SE0-000 bushing collar (2)
52316-SA5-000 bushing (2)
eH.
eH.
superbangkok
Aug 5, 2006 08:43 AM
nkcdjtribe
Jul 7, 2006 05:52 PM
