anti-sway bar bushings 95 civic
i purchased energy suspension rear sway bar bushings on ebay. now i've also decided to put on the sway bar endlinks and also the fronts. energy suspensions on ebay was not able to find rear endlinks for the 95 honda civic
http://www.suspension.com/civic.htm
does anyone know where to get rear poly urethane anti-sway bar bushings endlinks online? i live in thailand and the honda dealers only have rubber.
also, i put in a B18C engine with complete front end. the front sway bar measures 23 mm, however 22 and 24mm seem to be the sizes for the replacements, should i go with the 24mm?
any suggestions or URLs appreciated.
Re: anti-sway bar bushings 95 civic (superbangkok)
honestly, there is no endlinks that is urethane for rear sway bar endlinks. as for the front bushing your fine just using the stock rubber bushings from honda. you can purchase the 23mm front sway bar honda rubber bushings here:
http://www.jdmland.com
GreenBean
02-26-2004 01:01 PM
