tuning with 2 piece header?
Old Aug 18, 2014 | 10:16 AM
raverx3m's Avatar
Default tuning with 2 piece header?
wouldn't the 2 piece header leak at the sliding joint and affect the o2 readings when tuning?
I had try-why rep and welded them shut because I could see leaks on it
now I got a spfab toda replica header that's also a 2 piece design
Old Aug 19, 2014 | 08:50 PM
slowcivic2k's Avatar
Default Re: tuning with 2 piece header?
If the tubes are a snug fit you should get next to zero leakage. More exhaust would escape than would be drawn in on average due to pressure within the tube. A larger surface leak would be much more likely to affect O2 readings.
Bending a single tube that matches becomes much harder the more times you bend the pipe. A shorter pipe with a single bend can be correctly more readily than the same tube with 2 or more bends.
Ideally, the tubes ends would be chamfered to seal easier and with the aid of the springs, prevent most leaks.
Did you notice a difference in exhaust readings welded and un-welded? If so, please explain what sensor you were using.
Old Aug 19, 2014 | 08:53 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
the joints also become coated with carbon over time and that helps seal them, you might get a very slight leak at first but it will go away
Old Aug 23, 2014 | 09:55 PM
raverx3m's Avatar
not with this header I just got it not on the car yet
with the ebay try-why I had to weld everything up it was flimsy as ****
reg_lus
Jul 12, 2014 11:11 AM
ef9_lover
Aug 20, 2013 07:20 AM
uberEFtuner
Feb 12, 2011 06:56 AM
zx12ryder
May 8, 2010 04:35 PM
kay_animation
14
Feb 14, 2003 10:32 AM
