D16 iacv problems.please help.
Old Aug 14, 2014 | 04:00 PM
Cpt.trips's Avatar
Default D16 iacv problems.please help.
I have d16y7.Sick of messing with iacv. bought new one and the idol still "womps" like crazy. I guess air in the system.i can't get figure out how to bleed it all out. I jacked up front with cap off and let it run for a while.nothing. Any ideas?
Old Aug 14, 2014 | 04:51 PM
stupidhard's Avatar
Default Re: D16 iacv problems.please help.
air in what system? jacked up with the cap off?
ok ill do my best.... air in the coolant system... there is a bleeder on the thermostat housing or close to it. search for threads about bleeding the coolant system.
as for the wompage... its ok... that means the valve is doing its job working to compensate for something else like the throttle cable or other mechanical adjustment is out of spec or something as simple as a dirty throttle body.
idle hunting is a symptom created by another problem.
a good idea would be for you to read the FAQ and use the search...
find out what problems can cause idle hunting, list them, and check them off as you eliminate each possible cause.
good luck
-chris
Old Aug 14, 2014 | 05:04 PM
Cpt.trips's Avatar
I meant air in cooling system.i don't have bleeder valve. Iv replaced all coollant hoses,radiator,thermostat,and water pump.i just replaced the iacv and completely cleaned the entire intake manifold and throttle body. Now I can't get all the air out of system.iv tried everything. The idol whomps and I assume its from the air bubbles. I'm getting so frustrated.
Old Aug 14, 2014 | 05:08 PM
stupidhard's Avatar
also why did you create another thread? I see now that you already posted a thread bout this issue.
if you had bumped your original thread maybe I could give you a better answer. not enough info in this one...
ill say it again... read the FAQ and STICKY... use the SEARCH... posting duplicates will get you no where but in trouble with a moderator.
that is all....
-chris
9thgenidiot
May 30, 2016 03:57 PM
shogee
Jul 13, 2009 07:40 AM
diyer
Jul 2, 2008 01:10 PM
vtec92lude
Nov 3, 2004 03:52 PM
1.8T_EG
Oct 28, 2002 04:17 PM
