Fuel pump not priming!! Help*
Old Aug 12, 2014 | 01:56 PM
JdmR-ek's Avatar
Default Fuel pump not priming!! Fixed!
97 ek sedan. Cant hear the fuel pump priming. No check engine light comes on at all(thought that was weird) srs light, battery light and oil light is the only dash lights on.
Things I've checked.
-changed fuel pump relay
- cleaned/checked all grounds including g101 therm stat ground.
- checked fuses associated with problem.
Any ideas helpful. Anyway to test the fuel pump manually? Thanks in advance!
Old Aug 12, 2014 | 03:05 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Fuel pump not priming!! Help*
By fuel pump relay do you mean the main relay or ???
No CEL isn't good news, but replace the bulb first to verify that isn't the issue.
Old Aug 12, 2014 | 06:09 PM
Bently_Coop's Avatar
Steve at Heart
Listen for clicking in the main relay when turning the key on. Maybe time to change it out or resolder the OE one.
Old Aug 12, 2014 | 11:20 PM
holmesnmanny's Avatar
http://techauto.awardspace.com/
Towards the bottom he gives you the pin out for the fuel pump. You apply direct battery and ground to the fuel pump and check for fuel pressure. If not pressure then the pump is bad.
Old Aug 15, 2014 | 10:42 PM
vinceftlc's Avatar
did you fix the problem?
Old Aug 20, 2014 | 07:12 AM
JdmR-ek's Avatar
Old Aug 20, 2014 | 07:14 AM
JdmR-ek's Avatar
Yes I fixed the problem! Make sure the green plug is connected by the ecu lol. Stupid mistake. Changed distributor and spark plugs now she runs like a champ. Thanks everyone!
ghettoda9
Apr 13, 2011 10:03 AM
mihaelrosas
May 28, 2007 06:20 PM
EfSedanLove
17
Jan 22, 2007 07:15 PM
elude714
Oct 21, 2004 12:48 AM
tuan...
Aug 6, 2004 05:00 PM
