F22B2 to F22A4 question.
Old Aug 12, 2014 | 09:38 AM
jsnappdaddy88's Avatar
Default F22B2 to F22A4 question.
I've been looking on the forums and was just seeing if the f22a4 will drop in my 95 Accord that has the f22b2. I'm gonna build the F22a4 for FI. Is the motor mounts the same on the A4 and B2? And will it bolt up to my trans. It's a 5spd. I can't find a forsure answer on here in other forums.
Old Aug 13, 2014 | 08:10 AM
94 accord typeR's Avatar
Default Re: F22B2 to F22A4 question.
not a very common swap. why not just build the B2? 2.2L displacement should be about the same maybe with some minor modifications
Old Aug 13, 2014 | 08:29 AM
chrisnick's Avatar
http://www.cb7tuner.com/vbb/showthread.php?t=201795
It's fairly straight forward if you have no desire to run power steering and A/C, but it's actually a bit more complicated than it seems. It's far easier to replace the F22B2 with the F23A* or F22B1. The F22B1 is the easiest as just about everything is the same, all that really needs to be changed or added is the F22B1's ECU and VTEC wiring. Also, the F22A* head doesn't see any improvement in flow as-cast over the F23A*/F22B1's head, it only presents an advantage when it's been ported(Which the F23A*/F22B1's head can match up to .5 of lift on the cam) as seen in this thread: http://www.cb7tuner.com/vbb/showthread.php?t=198425 Most(if not all) OTS regrind camshaft profiles will not be able to take advantage of this. The biggest improvement that can be made is actually the intake manifold, on all F-series engines, which is dependent on camshaft profile, headflow, velocity, and displacement. The ports on the F22A* are substantially larger, but it seems the VTEC heads can make up for it with velocity.
Old Aug 15, 2014 | 03:05 AM
Thanks for the reply with good info. I'm new to the honda world and I'm gonna be building an bit or and Ive decided to go from my B2 to a B1 swap sense my B2 has some miles on it.
Old Aug 15, 2014 | 08:51 PM
chrisnick's Avatar
An F23 swap is really just as easy, and inexpensive. There's a couple of things you need to do if you plan to run the F23 intake manifold, but IMO, it's worth it. I just hydrolocked my car this past monday, and will be going the F23 route. The torque is worth it.
Old Aug 17, 2014 | 05:09 AM
Lost Again's Avatar
Ouch, that sucks. You should take pic's and document the changes needed and post a "how to" on here. I've seen some write ups on other places but not one on here?
http://www.hondaaccordforum.com/foru...gen-5-a-47757/
Old Aug 17, 2014 | 03:51 PM
MAD_MIKE's Avatar
MM Gruppe B
*lobs wrench into discussion*
Why not a F22B6?
*runs*
Old Aug 18, 2014 | 10:45 AM
chrisnick's Avatar
Might as well just go junkyard diving for the A6/B6 camshaft and corresponding ECU.
Old Aug 25, 2014 | 04:52 AM
I would like to find a F22b6. There's a pull your own part junkyard about 2 hours away and they have 17 accords 94-97 model. One of them is bound to have it
Old Aug 25, 2014 | 07:08 PM
chrisnick's Avatar
Only if some did the swap previously, as they come in the Odyssey LX's up to '97.
Old Sep 12, 2014 | 01:00 PM
youngboiCD7's Avatar
Its better off doing a f23 and keep the intake manifold rosko racing have adapter plate for it
Old Dec 1, 2016 | 11:35 AM
James Griffin's Avatar
93 accord 5 speed
I have been trying to find a replacement or repair for my select and shift cables. I've found a few used ones online but not really sure about them or the price. the select cable is okay but the shift cable came out of the boot/sleeve and kinked I've tried a few things to try and homemade repair but nothing is working of anyone has sum help thanks
tihz_wa
Apr 21, 2007 07:21 AM
deeweezy187
Sep 25, 2006 04:09 AM
sluger17
Oct 29, 2005 03:44 PM
uneek4dr
Nov 12, 2002 01:35 PM
Passaudi1.8t
Apr 24, 2002 08:08 AM
