93 civic skips when you first start it - Injector ???
Old Aug 12, 2014 | 02:15 AM
mgreene's Avatar
Default 93 civic skips when you first start it - Injector ???
For some reason my 93 civic skips when you first start it after sitting 8+ hours. It only last for 5-10 seconds then levels off. It has the 1.6 VTEC in it but I still have a complete 1.5 stock engine in the shop. Will the injecters from the 1.5 work in the 1.6? Also sometimes after driving 20 miles or so it may be hard to start. Spins fine but just won't catch. Has new fuel filter, plugs, wires,dist cap,rotor. Thanks for the advice.
Old Aug 12, 2014 | 09:25 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Injecter ???
Yes the D16Z6 and the D15B7 have the same 240cc Sauturated injectors.
If it's a D15B8, there might be an issue, I don't remember exactly but I get a niggling in the back of my mind that the B8 has smaller injectors.
Old Aug 12, 2014 | 09:46 AM
slogfilet's Avatar
I believe the B8/Z1 had 190cc injectors. The part number for the CX/VX injectors are different than the others, at least.
Old Aug 12, 2014 | 12:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Actually according to the list at HAMotorSports The Z6/B7/Z1/A6 all have 235cc while the Y8 has 240cc and the B8/Y7 have the 180cc. I suspect the Y5 would have 235cc injectors due to the same fuel requirements in normal (not vtec-e) operating mode but then again could be more like the Y7 and have 180cc.
D16Y7 1996-1997 Honda Civic CX,DX,LX SOHC 16V I4 180
D16Y8 1996-1997 Honda Civic EX SOHC 16V I4 VTEC 240
D16Z6 1992-1995 Honda Civic EX,Si SOHC 16V I4 VTEC 235
D15B7 1992-1995 Honda Civic DX,LX SOHC 16V I4 235
D15B8 1992-1995 Honda Civic CX SOHC 8V I4 180
D15Z1 1992-1995 Honda Civic VX SOHC 16V I4 VTEC_E 235
D16A6 1988-1991 Honda Civic Si,CRX Si SOHC 16V I4 235
Old Aug 12, 2014 | 12:41 PM
slogfilet's Avatar
Default Re: 93 civic skips when you first start it - Injector ???
I don't think their list is correct. The VX and CX share the same injector part number (06164-P05-A02), while the others (92-95, anyway) list 06164-P06-A02.
Still trying to map part number to cc... now I'm curious!
EDIT: I found these part numbers in the Majestic Honda parts catalog. I'm thinking they are either all the same flow rate (and just have different part numerbs due to fittings/grommets), or the CX/VX are a different part altogether. There are some VX gurus over at ecomodder.com, and the general consensus is that they are 190cc. That is my current understanding, but it's next to impossible to find a definitive answer.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d15z1-fuel-injectors-2315229/
Old Aug 12, 2014 | 06:28 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yeah just like I've always heard of the B7/A6/Z6 etc all being 240cc not 235cc.
Also of note, USDM CX (92-95 era) is the 12 valve B8 while a canadian CX (in the 92-95 era) is the 16 valve B7.
I was trying to find the the list I had come across before that showed them all as 240cc.
Would be nice to see a Honda spec sheet for the various injector part numbers....
Old Aug 18, 2014 | 01:15 PM
mgreene's Avatar
Thanks for the help
GarageNut
Jul 1, 2012 10:16 AM
White0420
Feb 24, 2012 11:13 PM
inovative91
Oct 12, 2011 01:35 PM
kc0vtj
13
Mar 1, 2007 12:40 PM
Hangmen
Oct 8, 2006 11:16 AM
