Boiling radiator
Old Aug 11, 2014 | 10:44 PM
slogfilet's Avatar
Default Boiling radiator
It's late, and my brain is fried. Stock D15Z1 in my VX hatch.
I went to swap my OEM thermostat back in, but discovered the lower bolt on the thermostat housing is rounded. No worries, I just filled it up with water until I can pick up an extractor tomorrow.
As I was burping the system with pure water, there were a lot of fine bubbles. I figured this was normal due to all the air in the system. I let it get up to temp with the cap up, and it was bubbling violently. My heart sank, as I've had head gasket issues in the past.
But then it dawned on me... could it have just been boiling? The cap was off, so it wasn't under pressure = boil-happy water.
I have a feeling I'm dumb.
Once it cools down a bit, I'll put actual coolant in it to verify.
Old Aug 11, 2014 | 10:56 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Boiling radiator
when cold is it bubbling violently? that would be exhaust gas bubbles.
Old Aug 11, 2014 | 10:59 PM
slogfilet's Avatar
Nope, cold it just had a stream of fine bubbles, and the occasional burp... once it got hot, it was spewing.
I'll put 50/50 in it in the morning and check again.
Old Aug 11, 2014 | 11:03 PM
normal.
EG6R
Aug 17, 2015 10:59 AM
panchlow
May 2, 2011 05:06 PM
Empyre JDM
May 11, 2010 12:51 PM
corince06
Jun 11, 2008 12:48 PM
drumsy
Sep 12, 2002 07:14 AM
