EM1 AC blowing not-cold air, hissing behind dash
Old Aug 11, 2014 | 05:38 AM
$amGD3's Avatar
Swaggylicious
Default EM1 AC blowing not-cold air, hissing behind dash
So a few days ago I noticed the AC in my EM1 started blowing warmer air than before and is now making a noticeable hissing sound behind the passenger-side dashboard area.
Did a quick google search and apparently it's evaporator related?
The hiss can be heard when the AC is running and for a few seconds after it is turned off.
Has anyone else had this issue? I haven't had time to look at it
What am I actually looking for? Is there a fix or should I head to the junkyard to get another evaporator?
Old Aug 11, 2014 | 05:41 AM
JDM_SOHC's Avatar
Default Re: EM1 AC blowing not-cold air, hissing behind dash
Leak?
Old Aug 11, 2014 | 06:25 AM
$amGD3's Avatar
Swaggylicious
That's what I'm thinking but is it a leak that can be fixed/patched or i gotta swap the whole evaporator?
Old Aug 11, 2014 | 06:44 AM
$amGD3's Avatar
Swaggylicious
What part of this diagram can go bad/malfunction? Do evap cores have a lifespan?
Old Aug 13, 2014 | 04:10 PM
$amGD3's Avatar
Swaggylicious
Anyone?
Old Aug 13, 2014 | 04:16 PM
Norlael's Avatar
#10 is most likely the culprit, check the o-rings on the feed port before buying a whole new core first though.
Old Aug 14, 2014 | 06:26 AM
$amGD3's Avatar
Swaggylicious
^thank you!
I was wondering if there could be a o-ring that could be replaced or something. I guess I'll have to go under there and check things out
Old Aug 14, 2014 | 07:34 PM
philipxhuff's Avatar
If it's low on freon sometime the expansion valve will make noise. I'd try getting the correct amount if freon in before replacing any parts.
Old Aug 15, 2014 | 04:10 PM
$amGD3's Avatar
Swaggylicious
Hmm interesting idea, maybe the valve is stuck?
Old Aug 16, 2014 | 07:00 PM
slowcivic2k's Avatar
A little hunting and I found:
Guy with same problem:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/all-new-c-components-problem-3219281/
Me doing my job:
https://honda-tech.com/forums/tech-misc-15/%2A%2A%2Aair-conditioning-c-guide-how-works-when-doesnt%2A%2A%2A-2900177/
Old Aug 25, 2014 | 10:48 AM
$amGD3's Avatar
Swaggylicious
^appreciate it
Read through those and I dont think they're directly similar but maybe I'm having issues with my expansion valve
The issue with just refilling with freon is that it's obviously not free to go to a shop and have it suck and recharge the freon in the system. Would be a waste to refill and have it instantly leak out
There's definitely a leak since freon doesnt just leak over a 48-hr period and it was just recharged last summer
gqstatus05
Aug 20, 2009 11:31 AM
Killtodie
Honda Civic (2001 - 2005)
23
Sep 4, 2007 12:57 AM
jetspeedz
Aug 8, 2007 07:43 PM
boostng r
Aug 6, 2006 08:47 PM
