1992 DEL SOL Service Manual
Hi Guys
Need a little assistance as I have just bought a 1992 Honda CRX DEL SOL it requires a bit of t l c, has any body got a Owners Manual from a car. I could do with a bit of help with this one. Thank you.
Root169
Root169
Re: 1992 DEL SOL Owners Manual.
Interestingly, Helm's only goes back to 93 for the Del Sol. Anyways, it's a print to order, 22 bucks:
http://www.helminc.com/helm/product2...600&itemtype=N
You can also order the Electrical Service Manual and the Factory Service Repair Manual and probably the auto body manual for the car from helminc. They make the best factory service repair manuals.
Re: 1992 DEL SOL Service Manual
I hope it works for you. Was looking at some info on the EUR 92 del sol and not sure if the engines will match up properly for the USDM 93 del sol.
1992 Honda CRX Del Sol 1.6 ESi
Honda CRX Del Sol 1.6 ESi, manufactured or sold in 1992, version for Europe
2-door roadster body type
FWD (front-wheel drive), manual 5-speed gearbox
petrol (gasoline) engine, displacement: 1590 cm3 / 96.8 cui
advertised power: 92 kW / 123 hp / 125 PS ( DIN ) / 6500 , torque: 142 Nm / 105 lb-ft / 5200 (see horsepower and torque curve)
characteristic dimensions: outside length: 4005 mm / 157.7 in, wheelbase: 2370 mm / 93.3 in
reference weights: base curb weight: 1060 kg / 2337 lbs, gross weight GVWR: 1320 kg / 2910 lbs
top speed: 190 km/h (118 mph) (declared by factory);
accelerations: 0- 60 mph 8.8 s, 0- 100 km/h 9.3 s (declared by factory), 1/4 mile drag time (402 m) 16.9 s (a-c simulation) (see detailed performance data review)
fuel consumption and mileage: 7.5 l/100km / 37.8 mpg (imp.) / 31.6 mpg (U.S.) / 13.4 km/l average estimated by a-c: 7.9 l/100km / 35.8 mpg (imp.) / 29.8 mpg (U.S.) / 12.7 km/l
For the table with this car full photo gallery and complete technical specifications (including final drive and gear ratios, powertrain description, inside and outside dimensions etc.), full performance and economy data, or to compare up to 5 cars side-by-side - click one of the the buttons below:
1992 Honda CRX Del Sol 1.6 VTi
Honda CRX Del Sol 1.6 VTi, manufactured or sold in 1992, version for Europe
petrol (gasoline) engine, displacement: 1595 cm3 / 97.5 cui
advertised power: 118 kW / 158 hp / 160 PS ( DIN ) / 7600 , torque: 150 Nm / 111 lb-ft / 7000 (see horsepower and torque curve)
reference weights: base curb weight: 1110 kg / 2447 lbs, gross weight GVWR: 1430 kg / 3153 lbs
top speed: 211 km/h (131 mph) (declared by factory);
accelerations: 0- 60 mph 7.7 s, 0- 100 km/h 8.2 s (declared by factory), 1/4 mile drag time (402 m) 16.1 s (a-c simulation) (see detailed performance data review)
fuel consumption and mileage: 7.6 l/100km / 37 mpg (imp.) / 30.9 mpg (U.S.) / 13.1 km/l average estimated by a-c: 9 l/100km / 31.4 mpg (imp.) / 26.1 mpg (U.S.) / 11.1 km/l
There is an ESi automatic for Europe also.
The SiR was Japan as was teh VXi
qat727
02-28-2006 08:57 PM
