Neptune y8 map timing sync question
Old Aug 11, 2014 | 04:27 AM
RACEPAK's Avatar
Default Neptune y8 map timing sync question
hello guys,
the idle area in the neptune y8 base map is 22deg.
do i need to sync the dizzy to 22deg?
thanks
Old Aug 11, 2014 | 08:38 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Neptune y8 map timing sync question
No.
Your base timing (distributor) should be set, per the FSM, to whatever the base timing is under the Main tab in the NepTune preferences. Same tab where you calibrate the TPS.
Old Aug 13, 2014 | 10:35 AM
blackeg's Avatar
Originally Posted by spAdam
No.
yep. what are those y8's 14 degrees btdc not 16 like most other hondas?
v8killaz
May 20, 2012 04:20 PM
98h22
Jun 19, 2009 06:13 PM
THEDirtyDseriesWOOT
Aug 19, 2006 07:40 PM
Racergurlie
Jul 29, 2003 02:49 PM
GReddyB18C
Sep 7, 2002 05:24 PM
