Civic Intermittent Cooling Issue
Old Aug 11, 2014 | 01:39 AM
keatonmoney's Avatar
Default Civic Intermittent Cooling Issue
Hi all,
I'm Keaton and I recently joined the forum after searching and not finding my specific problem. I have a 2000 Civic EX coupe with a D16Y8.
Occasionally (about 1 in 10 drives), the engine temp will start to climb steadily when the car is stopped and idling. I have to rev the engine and force coolant through to get it back down. This problem doesn't seem to be affected by use of the A/C or any other factor.
I replaced the cooling fan relay just to rule it out because it's easy and cheap. Also burped the cooling system to get rid of any air pockets. Did a pressure test and the system held pressure. I'm kinda thinking bad thermostat, but I wanted to see what else it might be before just blindly replacing parts.
Old Aug 11, 2014 | 10:48 AM
turbohatch96y7's Avatar
When the needle rises are the fans still running?
Old Aug 11, 2014 | 12:21 PM
Default Re: Civic Intermittent Cooling Issue
Yes.
Old Aug 11, 2014 | 12:28 PM
Balto's Avatar
Originally Posted by keatonmoney
Yes.
A blown head gasket would cause that wouldn't it? That or your water pump is going out. Could be wrong though I'm not the smartest guy.
Old Aug 11, 2014 | 12:51 PM
The water pump was replaced less than a year ago with the timing belt. There isn't any oil in the coolant or vice-versa. No smoke from the exhaust either. I suppose I could do the turkey baster test, but I don't really see the head gasket being the problem.
Tmango
Jun 22, 2019 03:29 PM
Manifest113
Jul 30, 2014 06:09 PM
Chip Phillips
10
Dec 29, 2008 05:32 AM
D16Z6_turbo
Sep 10, 2006 08:57 PM
4505
Oct 12, 2003 05:28 PM
