Camber issue?
Hi there, I was wondering if anything was wrong about getting barely 3.5° camber in the front on my 1994 hatch while it was made for having 5.5°? Camber kit is Blox Competition Series. I have no issues in the rear getting 5.5°...
What's the problem? Camber kit or my car? Or everything is ok?
Thanks
Thanks
Cool Cool Island Breezes. BOY-EE
Sometimes you see a car on the internet or a magazine with Works or Rays or Starks (or some other rare wheel) that were forced under the fenders using some sort of innovation, body work, repaint, and full body coilovers in order to be trailered to and from some crappy scene....and you think, "hey, I can do the same thing to my DD with lowering springs and some XXR's".
Then you find out that maybe you were wrong and you end up back on the internet. YOLO. #swag
Lol i'm not calling blox ~
My car height is adjustable up to -150 (Zenky Racing coilovers) actually -120. I also have installed blackworks lower control arms, F7 rear lower bars ...
btw this is my "parking" car, I own a turbocharged DC5 and full motor ITB EK K20 for serious things, I just wanna give a try to hellaflush ^_^
maybe you should listen to it and forget about the dumb scene. Or go over to the appearance forum where people drool over crooked wheels.
OP...the camber is adjustable up to -5.5°. Camber is dependent on height. You will also probably start to hit the camber joint on the suspension spring at some point.
How low is your car?
So you lowered it 120mm from stock (around 4.75")? You should be able to get -3.5° camber with stock control arms at that point.
This may seem obvious, but did you slide the camber ball joint all the way in? Pics of the car sitting on the ground and pics of the camber kit installed?
Ross2852
Jul 28, 2005 06:06 PM
