Engine hesitation
Old Aug 6, 2014 | 07:35 PM
saintbhts's Avatar
Default Engine hesitation
hey whats up everyone i have a question. Recently i changed my fuel filter because it was clogged up, muddy fuel came out of it when i changed it but today when i took it for a run after changing the fuel filter and my engine hesitates when accelerating as before. Can my fuel injectors be clogged up also since the filter was dirty? and if so how can i check them and clean them?
Old Aug 6, 2014 | 10:09 PM
holmesnmanny's Avatar
Default Re: Engine hesitation
It's possible. When was the last time you changed your distributor cap, distributor rotor, and spark plugs ?
Also, year, make and model ?
Old Aug 6, 2014 | 11:28 PM
saintbhts's Avatar
i changed the distributor, spark plugs, spark wires also, catalytic converter
its a 94 honda accord ex
Old Aug 7, 2014 | 02:15 AM
If you take the injectors out you can pop them open and inspect the filters inside. I would think if the filter is clean the injector pintles are also clean. However, if the filters are clogged up I would think you should either pull some from the junkyard, get some rebuilt ones, or do a return and rebuild. But you can first see if the filters are dirty and if so, clean them with some brake cleaner and put em back in and road test.
How bad is the hesitation ? Have you tried checking for stored check engine codes ?
Old Aug 7, 2014 | 03:37 PM
saintbhts's Avatar
oh ok i get you
the hesitation happens when i accelerate. yesterday i tried going up a hill and felt like something pushing the car back but started picking up speed slowly until it went back to normal after 3k rpm
oh yeah all this started to happen after i had fresh fuel into the tank. i know its not bad fuel because i refilled it again and started to act worse
Old Aug 7, 2014 | 05:16 PM
94 accord typeR's Avatar
fuel pumps tend to show their age when its hot outside. i should've took pics of my strainer. it was yellow and dirty as *****. new strainers are white. P.S. i use premium fuel
Old Aug 7, 2014 | 05:26 PM
LF979883's Avatar
Sounds about right to me
Old Aug 7, 2014 | 10:11 PM
MAD_MIKE's Avatar
MM Gruppe B
If the car is hesitating only at part throttle in the 2K rpm range, more than likely your EGR ports are clogged. Luckily on 94-97 F22B1/F22B2 engines there is a separate EGR manifold that can be removed and easily cleaned. Check the Accord FAQ at the top of the page on how to clean them.
If there was a fueling issue, the car would lean misfire and the stuttering would get worse in the higher rpms, not go away.
Old Aug 7, 2014 | 10:14 PM
Disconnect the egr valve connector and run the car warmed up and when the check engine light comes on see if the car runs better. If it runs better the issue lies with the egr being too dirty.
Old Aug 7, 2014 | 11:15 PM
saintbhts's Avatar
thanks everyone for the info
i found the culprit already its actually the fuel pump. It started to make a noise like if it was overheating by the tailpipe and i turned of the car for about 30 mins and then turned it back on and the noise was gone. My friend that has been a mechanic for 20+ years helped me out. He said that the pump drops on pressure and sounds like its gonna soon give out, he is right because my car left me stranded once already and let the car sit over night and started right up again.
Old Aug 7, 2014 | 11:22 PM
Sounds good, if that's not the culprit by some chance feel free to keep us posted.
syvpunk
Jul 29, 2010 04:10 AM
HybridBB6
Nov 21, 2007 09:30 PM
VTECdTypS
Sep 22, 2005 03:25 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
brbHPR
Jan 29, 2002 08:05 PM
