swap help !!! d16y8 to d16z6 !
Old Aug 6, 2014 | 02:56 PM
Kevokay123's Avatar
Default swap help !!! d16y8 to d16z6 !
so i have a 98 Honda civic ex, and my engine blew last week. since its my daily driver i went and bought a cheap working d16z6 swap with 147 miles on it. I've done my research and i know my car is obd2a and the z6 is obd1. if im not mistaking i'll need a obd2a to obd1 jumper harness and a obd1 ecu witch most likely will be a p28. can i just drop the full swap in and use the harness and the p28 ecu and call it a day ? im really new too this and some forms confuse me and say you could use your ob2 ecu ? i just want too drop the full swap in the car and not have too use parts from the y8. please help you guys. i'll appreciate it.
Old Aug 6, 2014 | 04:12 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: swap help !!! d16y8 to d16z6 !
What are your emissions testing like? The OBD1 ECU won't pass the plug in test.
Old Aug 6, 2014 | 04:19 PM
slomofo's Avatar
GDD Member
No emissions, get a jumper harness.
Emissions = Swap out the oil pump and intake manifold, tap a hole for knock sensor, and reuse all the Y8 stuff.
Been a while since I've done something like this, but I think your power steering bracket isn't going to line up properly and you'll have to do some mix/matching with Z6/Y8 power steering components. The timing covers aren't going to fit perfectly, you'll need to trim, AND you'll end up with two oil dipsticks.
Old Aug 6, 2014 | 04:21 PM
shotoutacc0rd's Avatar
"AND you'll end up with two oil dipsticks."
yo dog i herd you like checking the oil so we added another dipstick so you can check the oil while you're checking the oil.
srsly tho? Thats weird.
Old Aug 6, 2014 | 07:52 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
^^^If I knew how to quote this in my sig, I would
Old Aug 7, 2014 | 02:34 AM
Technical Hero
If you go the emissions route I'd just bypass the CKF
http://technet.ff-squad.com/ckftrick.htm
Old Aug 7, 2014 | 02:51 PM
slomofo's Avatar
GDD Member
Cool trick, does that work on D17A1 engines?
Old Aug 11, 2014 | 05:50 AM
Kevokay123's Avatar
i know this guy that charges $150 to pass your emmission. so im okay with the emmision.
Old Aug 11, 2014 | 05:57 AM
Kevokay123's Avatar
so obd2a to obd1 jumper harness and a p28 ecu should be good right ? i have both those things, i just really need my car up and runing again. im soo sick and tierd of taking the bus lol.
Old Aug 11, 2014 | 01:58 PM
slomofo's Avatar
GDD Member
Engine not going to plug into your car, I don't know why I initially said jumper harness.
You need to reuse all of your old stuff with the new engine otherwise the wire harness isn't going to plug in. The only thing off the new engine you'll keep is the distributor, but you'll have to repin it with the old OBDII plug.
Old Aug 11, 2014 | 03:53 PM
Fnix's Avatar
I did the same swap. I had to get an OBD jumper harness, wire harness from a civic EX, injector adapter, and distributor adapter.
Kevokay123
Aug 11, 2014 02:37 PM
nightscream
11
Oct 28, 2010 04:02 PM
AndrewHuffman
13
Jul 30, 2008 12:19 PM
bunnyx
Apr 30, 2008 01:53 AM
b18bcrxhf
Dec 9, 2006 11:11 AM
