Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Passenger Rear window issue
Old Aug 4, 2014 | 07:26 PM
Plinko's Avatar
Default Passenger Rear window issue
I am having an issue with my rear passenger window on my 2002 EX sedan. The switch on the door lowers/raises the window with no issues, but it does not work from the master switch when I drive. Since it's right behind me, if I am wanting to roll it down I can reach back but I would like to figure out and fix this issue.
If anyone could point me in the right direction to diagnose and/or fix this problem, it would be much appreciated. I did some searching and found similar problems but most involve the door switch not working while the master works, or both not working, so hoping someone else has gone through this as well.
Thanks in advance.
Old Aug 5, 2014 | 01:41 PM
lazlong's Avatar
Default Re: Passenger Rear window issue
I think the master switch is bad. Do the Master Switch Input Test just to be sure: https://honda-tech.com/forums/showth...ght=input+test
Old Aug 9, 2014 | 07:52 AM
99HiluxSurf185's Avatar
Sounds to me like the master switch is bad. The same thing happen to my aunts accord.
EndlEEsss
Feb 23, 2023 03:46 AM
H.N.F
May 18, 2016 07:42 AM
qinfujun
Jun 30, 2014 08:33 PM
hondagal2004
Nov 27, 2013 07:55 PM
einzelherz
Aug 26, 2013 06:41 AM
