b16 valve replacement question
Old Aug 3, 2014 | 09:22 AM
ldobai23's Avatar
Default b16 valve replacement question
I am new to engine building but I have done a lot of research but I cannot find the answer to this question. I have a b16 bare block and I am going to be using stock b16 valves in the bare block but not the original ones that came in it. so my question is can I just take the valves, do a light hand lap and reassemble? keep in mind the valves I am putting in are used. Any input would be appreciated
Old Aug 3, 2014 | 07:38 PM
civic-steve-94's Avatar
Default Re: b16 valve replacement question
I hand lapped in the valves that are in my head and they were new. Just check and make sure the surface isn't burn or messed up.
Old Aug 3, 2014 | 08:49 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes,it is best to make sure the seal is good, since using different valves may result in leakage....
Old Aug 4, 2014 | 08:44 AM
ldobai23's Avatar
Gotcha, now as far as lapping, is there is certain way to do it. From what I have seen the best is to get the suction cup hand lap tool and go back and forth. What is the correct method of lapping? and how long for each valve.
Also, is there a specific lapping paste that is good for hondas or are they all pretty much the same.
Old Aug 6, 2014 | 07:02 PM
The way I was taught was to use suction cup light pressure on valve and pull up and rotate the valve a quarter turn every so often. Pull the valve up and clean off valve grinding compound from valve and seat. You should see a light gray line all the way around the valve and seat.
diegoC209
Sep 19, 2010 10:10 AM
b00sted_hatch
Apr 15, 2006 03:43 PM
Littlegreend15
May 30, 2005 11:40 AM
