b18 b16 valves interchangable?
heres what happpened, over revved, problems, turned out to be bent valves, the post is here https://honda-tech.com/zerothread?id=1260163 . anyway, i'm pulling the head and taking it to a machine shop to check/fix valve seats, and obviously i need some new valves, so my question is, are jdm b18c valves interchangable with b16 valves, because theres a honda dealer close where i can order some new b16 valves, but no acura dealer close, or possabley somewhere else i can buy valves, i don't want to spend the money on performance valves, i just want to replace the bent ones, and i don't know where to get them other than a dealer
Re: b18 b16 valves interchangable? (Littlegreend15)
I'm not sure if the valves are the same.
The only thing making me belive they aren't is that the b16 head may be setup differently to work on the 1.6L motor. It might be that the valves will be a bit smaller then the GSR b18c1 valves.
Search here on honda-tech and you can probobly pickup a set of valves for cheap for the b16
Compare the part numbers @
http://www.acuraparts247.com
http://www.hondapartssource.com
If they are the same you are good to go.
jceltalentoso
14
01-20-2012 03:45 AM
jceltalentoso
01-18-2012 10:23 AM
