Exhaust smells like gas.
Ok so this is normally a really easy answer... But here is what I am working with and what is not normal about the situation.
I am working with a 95 Civic Ex MT D16z6.
Symptoms are:
The exhaust smells like fuel once it's warm.
The car will run really rough on start up after the motor is warm but will clear up by the time I have backed out of the parking spot.
I have noticed that there are some days where the car is the normal power expected from a D16z6 with 130,00 and others it is just a dog and doesn't want to get out from under its self until it gets to Vtec then it will move.
Also it seems as though the car is revving out to the proper RPM by the sound of the motor and pull but the rev limit kicks in at 6500 according to the dash.
Parts that have been replaced
Cap/Rotor/Plugs/Wires
New Denso 02 sensor
FPR
New Cone Filter
Synthetic Oil Change
I set the timing to what the Honda manual called for when doing my timing belt and water pump so unless it has magically changed without the distributor moving then it should be correct and the problems where there before doing the timing any ways.
I just don't know weather to start with the MAP CPS or Distributor I was kind of leaning to the Distributor but that is like a $250 part and I think I have a D Series TB laying around here some where that I could take the CPS and MAP off of and see if that makes a difference. If not a D Series then I know I have a F22 and a couple H22 TB's around here would the sensors work off of those? Any help is very much appreciated.
Symptoms are:
New Denso 02 sensor
FPR
New Cone Filter
You could try doing a resistance check on all four injectors and see if one of the injectors differs greatly from the other 3. If all of them are right around the same resistance between say 12-15 ohms, then it would appear to not be stuck open. I believe the injectors are a "Normally Closed" type of electrical mechanical device.
If one of the injectors has a significant variance of resistance to the others, that would be your faulty injector.
Can you be any more vague? What sensors?
I would suggest a noid light test to verify proper signalling to the injectors would be the next step.
I'm assuming the car still runs fine and idles fine just smells of gas? If it's running a little rough, I'd pull a current compression test to rule out broken ring or cracked ring land. Low enough compression I believe can cause a dirty burn leaving fuel in the exhaust.
And if no one mentioned anywhere in the thread, STOP DRIVING IT!!! YOu are washing the cylinders walls dry with that extra fuel and your oil is probably the consistency of ink right about now. That's a ticking time bomb right there. You'll get a rod through the block pretty soon.
OP just start with the injectors and report back, its cool sometimes to think 3 steps in advance.
Ok, check your fuel pressure - since you've already changed the FPR (and I'm hoping you went OEM here). Quickest thing to do is buy the FP guage on eBay for $19, it sits on top of your fuel filter at the firewall. If you're leaking fuel into the cylinders from a fuel injector you will see no pressure at the guage when the car is off. Autozone etc dont rent this, I tried.
If its your injectors you can mail them for servicing takes about a week. I sent mine on Saturday, they got it on Tuesday and by Saturday I got them back.
I dont think its compression, you're pissing fuel in your chamber. How's your mpg? O2 wont throw a code because it only looks for oxygen in the exhaust gas, but it would be nice to know your fuel trims.
MPG sucks compared to other civic's I have had but I live in the hills and have my foot into it everywhere I go so I get around 150 miles per tank lol I didn't get to test the injectors yesterday because it was raining and I don't have a shop to do it in but the weather cleared up today so it is on I will post back tonight. On a side note to grumblemarc I did a OIL change like 4 or 5 days ago the oil was black but didn't smell of gas or anything so at least the motor is happy with some fresh synthetic oil
NOID light test is normally next.
I'd also think about the Primary O2 sensor, if it's faulty it could be not trimming the fuel thus pumping more gas than it should.
There is also the part about fuel pressure, not sure if a bad regulator could cause too much gas but it is still a part of the fuel system that can go awry.
And just as an FYI, the NOID light should be blinking when you are cranking the engine. If one of the lights stays on solid, that's the problem and isn't the injector but the fuel control which I believe is part of the ECU. Not sure if a short of some sort could cause constant voltage to the injector......
Anyways, you test each injector connector. Make sure to unhook all 4 injector plugs and both plugs to the distributor before cranking the motor repeatedly.
That89Si
Feb 20, 2018 05:09 PM
embersanenders
Jul 16, 2012 01:30 PM
xXx Justin xXx
Jun 9, 2008 06:44 AM
SOHC_Brian
Jan 1, 2005 06:07 PM
