Helpp !!! Starting up jdm h22a
Old Aug 2, 2014 | 06:07 AM
ekhatch110's Avatar
Default Helpp !!! Starting up jdm h22a
I got a h2b that i took the head off to rebuild & now that i got the head from the machine shop i put everything back on im having a problem to start it up , people are telling me that the motor doesnt have compression , i did a compression test it was good i want to know what could cause this
ekhatch110's Avatar
Default Re: Helpp !!! Starting up jdm h22a
I need help asap
Old Aug 2, 2014 | 06:08 AM
ekhatch110's Avatar
I think the motor is off timing by a tooth will that matter
Old Aug 2, 2014 | 07:45 AM
ekhatch110's Avatar
Bumppppp
Old Aug 7, 2014 | 02:30 AM
MKCSRet's Avatar
I would have to agree with ekhatch110, in that you may want to start by rechecking the timing allignment. Do not forget to troubleshoot your ignition system as well. { Air / Fuel / Compression / Ignition } No spark / No fire. Most of the time, our problems are caused by the most simplest of issues, generally forgetting one little thing.
Old Aug 7, 2014 | 06:25 AM
KeepUp's Avatar
If it is off by a tooth, engine wont start and I've witnessed this. We checked for spark, fuel, air...then timing and turned out being off by a tooth. We fixed the problem and engine started up just fine. Definitely check for timing and get back to us.
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
tegmech
Nov 9, 2004 05:58 AM
TURBO
Jul 2, 2004 10:05 AM
ericlee303
Apr 28, 2004 03:31 PM
C ronic
Apr 8, 2003 08:03 PM
