0 rear camber pros/cons?
I'll be raising/lowering my crx this weekend and I'm curious what are the benefits and cons to 0 camber on rear wheels. I'll be doing between -1 to -1.8 on front.
Thoughts?
Thoughts?
Stock spec is -.25* with a range of -.6 ~ -2.6.
Going to 0 isn't a great thing. It probably looks cool to some people when it's parked.
The contact patch of your tires around turns will suffer.
Front spec is -1.3 ~ -3.3
Thank you i wasn't sure if there was any handling draw backs other than tire wear
0* is good for drag racing. Other than that, you suffer in the corners. I wouldn't go as far to call it 'dangerous' but the factory spec was designed with safety in mind.
bdooley
12
Jun 30, 2007 05:39 AM
Racerage1
Jun 14, 2003 11:33 PM
itr1236
Sep 24, 2002 06:18 AM
