Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Replacing 01 Civic Head Gasket. Easy as EK's?!?
Old Jul 29, 2014 | 12:44 AM
jermo's Avatar
Default Replacing 01 Civic Head Gasket. Easy as EK's?!?
Whats up fellas!
I do mechanic work at my house as a hobby and have changed many 92-95 and 96-00 civic head gaskets, they are pretty easy. I have an 01 civic EX and it seems to be a bit different. With the EK's i can just loosen the bolt on the tensioner, pull up on the timing belt and slip the timing belt off the cam. Doesn't seem like i can do the same with an 01 is that correct? The timing belt, water pump and tensioner were replaced recently so i am trying not to touch those, just slip the timing belt off the cam and go about changing the head gasket like i would an ek. Just making sure if this is or is not possible and if i absolutely have to remove everything just to get the head off?!? Thanks!
Old Jul 29, 2014 | 10:36 PM
jermo's Avatar
Default Re: Replacing 01 Civic Head Gasket. Easy as EK's?!?
Was hoping someone would answer this before i started on the headgasket tomorrow =/
Old Jul 30, 2014 | 02:26 PM
toyomatt84's Avatar
Sanji
I don't have any firsthand experience to share, as I ditched the D17 many years ago.
prodjay10
Nov 12, 2016 06:42 PM
nicknack25
15
Oct 26, 2010 08:16 PM
silentbeatz
Aug 15, 2005 06:44 PM
420aNT
May 5, 2003 08:13 AM
Piston_Honda
12
Feb 21, 2002 06:18 AM
