More problems f22b2---f23a
Old Jul 27, 2014 | 12:27 PM
Savintims's Avatar
Default More problems f22b2---f23a
More problems.....
We got it running and as we were testing it the temp gauge went to the top. Checked the engine but it wasn't overheating. As we drove it back to base, the car was acting strange on sudden stops and when shifting gears. The speedo sensor 3p connector is a little screwed up (going to order a new one) so we tried to improvise (this happened when we pulled the engine out).
We decided to swap the thermostat and swap the battery cables (since the previous battery cables would not stay gripped to the terminals.
Now the car won't start again. It gets spark, the ground cable is grounded and we are not sure what the heck is going on. Any ideas?
Old Jul 27, 2014 | 07:21 PM
accordturb96's Avatar
Default Re: More problems f22b2---f23a
did you connect the positive cable that goes from the battery to the fuse box?
Old Jul 28, 2014 | 11:12 PM
Savintims's Avatar
Yeah, thanks for that though. Started to check the fuses and some of them have the wrong amps on them; however, they are the ones that are for trivial things like interior light. We are going to replace those and the 3p connector for the speedo, hopefully, this upcoming weekend.
Old Jul 29, 2014 | 12:07 AM
NerfGunner420's Avatar
its grounding out. the temp sender sensor is bad or your wiring is grounding somewhere
Old Aug 26, 2014 | 03:57 PM
Savintims's Avatar
It was the distributor cables. They were not pushed in. Thanks for the help guys!
B16afmaxt
Oct 19, 2009 04:30 PM
biggjerryc
Oct 23, 2008 08:45 PM
qbansir
Jul 13, 2008 07:37 PM
gumbybum
Feb 8, 2003 11:25 PM
VTi NA
Nov 14, 2001 04:54 PM
