Do you have to make cutouts for toda cam gears?
Old Oct 31, 2002 | 08:33 AM
vtec69's Avatar
Default Do you have to make cutouts for toda cam gears?
I was installing my toda cam gears last night onto my crower cams and when i went to place the vlave cover on, the bolts on the cam gear were hitting the valve cover
Do they always do this or did i do something wrong?
Thanks in advance
-Brian
Old Oct 31, 2002 | 08:35 AM
Reid's Avatar
Global Moderator
Default Re: Do you have to make cutouts for toda cam gears? (vtec69)
You don't need to cut the valve cover.
Something is installed incorrectly.
Old Oct 31, 2002 | 08:37 AM
RTW DC2R's Avatar
Default Re: Do you have to make cutouts for toda cam gears? (Reid)
agreed they should fit the same way the stock gears fit. no cutting necessary.
Old Oct 31, 2002 | 08:38 AM
Austin's Avatar
no need to cut the valve cover...I'm running around with an uncut valve cover with my TODA Gen 2 cam gears, I have an cut valve cover for tuning purposes.
Austin
Old Oct 31, 2002 | 09:00 AM
vtec69's Avatar
Default Re: Do you have to make cutouts for toda cam gears? (Austin)
what do you think i did wrong?
Old Oct 31, 2002 | 09:01 AM
vtec69's Avatar
maybe they need to be pushed toward the distrubter a little?
Old Oct 31, 2002 | 09:04 AM
sackdz's Avatar
You put in a cam from a straight six.
Old Oct 31, 2002 | 09:06 AM
RTW DC2R's Avatar
Default Re: Do you have to make cutouts for toda cam gears? (sackdz)
seems like you just didnt tighten the gears on enough.
Old Oct 31, 2002 | 09:08 AM
vtec69's Avatar
Default Re: Do you have to make cutouts for toda cam gears? (RTW DC2)
i torqued them down to the helms manual spec
Old Oct 31, 2002 | 03:19 PM
vtec69's Avatar
anyone else?
Old Oct 31, 2002 | 03:53 PM
sgT's Avatar
sgT
did u use the bolts that came with the gears??
Old Oct 31, 2002 | 03:58 PM
frogsr's Avatar
i agree you've probably installed something wrong. did you double check to make sure the little cam gear key things are set properly in between the cam and the cam gear itself? and, you were referring to the actual valve cover, right, and not the black plastic cover on the backside of the cam gears (between the head and cam gears)? after i installed mine, i had some rubbing on the plastic and cam gear, but it went away after the plastic rubbed down a little...
Old Oct 31, 2002 | 04:04 PM
vtec69's Avatar
Default Re: Do you have to make cutouts for toda cam gears? (sgT)
yes
Old Oct 31, 2002 | 04:52 PM
skunked's Avatar
pics would help.....
Old Oct 31, 2002 | 06:26 PM
xjohnx's Avatar
Did oyu use the bolts the todas came with? or the stock bolts? todas bolts are longer than the stock ones from what i remember. The hole in the crowers may not be deep enough to allow for them to go all the way in, try using the stock bolts.
athoughts
Feb 5, 2005 09:06 AM
max8455
Nov 15, 2004 10:15 AM
Weel
Mar 17, 2004 05:01 PM
flyrod
Nov 12, 2003 05:50 AM
nerdish
Mar 3, 2002 08:44 PM
